Thread: Retrofit a 2006 Jacuzzi J345 with a SWCG?
    May 2012
    Toronto, ON
    463
    I have the above mentioned stand-alone spa which uses bromine tablets in a dispenser inside the filter. If possible I would like to switch to a SWCG - I have a SWCG (Jandy Aquapure 1400) for my pool and really like the convenience of that. The bromine dispenser isn't that inconvenient but I would prefer an SWCG if possible.
    Is a retrofit SWCG possible? If so then where does the SWCG go? Does it tie into the existing pump/filter system?
    If this is possible, any recommendations on what to use for my spa?
    edit - There is a product called TechniChlor - does anyone have any experience with one of these. It is under C$300 so seems quite reasonable.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    May 2012
    Toronto, ON
    463
    Re: Retrofit a 2006 Jacuzzi J345 with a SWCG?
    To answer my own thread, here is a thread from another site that has very positive feedback on the TechniChlor.
