Results 1 to 8 of 8
Thread: Combining two pool finishes on pool edge
    Jul 2016
    New Smyrna fl
    32
    Is it possible to have a sand pebble finish on the top of this shelf and a blue pebble finish on the wall of shelf without a boarder tile?
    30,429
    Re: Combining two pool finishes on pool edge
    What does your PB say? He'll be doing the work, right? Not many PB's on this forum.
    Jul 2016
    New Smyrna fl
    32
    No, wasn't sure if any pool buyers had this done and had any suggestions on how it was done. Should I check forum rules, am I not suppose to ask questions like this?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    It is fine to ask the question, I don't see that he suggests otherwise in his answer to you. I have seen two color finishes, not all installers will do it. And it seems to cost nearly twice as much to do it because it is basically two different set ups and pool finishes.
    Jul 2016
    New Smyrna fl
    32
    Ok just wanted to make sure. We already have price set for the two colors, but right now on that lip of sun shelf there is a line of tile what we are afraid may have our pool looking too busy. Was wondering if there were any other methods to have these two finishes be separate without having the tile to separate.
    DFW, TX
    24,502
    I've seen plasterers butt the two finishes together with nothing in between.
    Jan 2012
    340
    If your builder can't get the bubbler centered, keep the strip of tile.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    Two finishes are rather common around here. Something to consider is there will be a straight line where one color starts and the other ends. I've seen pools where the colors were attempted to be faded together and the results looked a little odd.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
