Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Venting an ODK under covered patio
    Jun 2016
    FL
    901
    We are thinking ahead with our covered patio/lanai build. It is going to be 40x16 with essentially room for 3 activities: lounging, dining, and cooking. The best option for layout is to build an outdoor kitchen with grill in the far corner which is fully enclosed on 2 sides (Since our home is on a zero lot line, that side of the patio will be a full privacy wall attached to the roof and column/post). The grill would likely be up against one of the two enclosed sides vs the open air facing the pool.
    Do we need to somehow vent/exhaust this through the roof or through the privacy wall? I'm not sure the two open sides will provide enough ventilation and I'm afraid to char my brand new covered patio.
    Any thoughts/recommendations?
    JoyfulNoise's Avatar
    May 2015
    13,208
    Re: Venting an ODK under covered patio
    What kind of cooking gear are you planning for the ODK? Gas grille, charcoal, smoker??
    I'm always a fan of good exhaust because I find it both annoying to cook with smoke blowing in your face and you don't want to smoke out guests sitting nearby.
    Matt
    Jun 2016
    FL
    901
    We arent going to go crazy. It will likely be a built in propane grill.
    Jun 2016
    FL
    901
    here are some design pics. The far left side of the covered patio (where the outdoor shower is now) will be a fully enclosed wall. I was thinking of moving the grill against that wall.
    Brian_kilpatrick_pdf__page_6_of_8_ by fsubk, on Flickr
    Brian_kilpatrick_pdf__page_7_of_8_ by fsubk, on Flickr
    May 2015
    13,208
    I would definitely add an exhaust fan if the grille will be against a fully enclosed wall. Even with just a propane grille you'll get a lot of smoke.
    Matt
    Nov 2014
    Dallas Texas
    165
    Here's our vent hood. I think having them is probably a good thing, but most places don't require them by code.
    IG 16 x 50 Gunite. 3.5' - 9' depth 37,400 gallons 146LF perimeter and 863 square feet, 3 skimmers, 3 Pentair LED lights, 2 main drains, 6 pool returns, 1 vacuum line, 1 Pentair Intelliflo VS Pump, 7x7 Spa attached with 1 Pentair LED Light raised 15 inches and 6 HydroAir Jets, 2 HP blower, Pentair DE60 Filter, Pentair Intellitouch I-7 w/Wireless remote, Pentair SWG 400k BTU Heater, Glacier Chiller. My 2015-2016 build thread.
    May 2015
    13,208
    Quote Originally Posted by Itsjustme0770 View Post
    Beautiful setup you have there. Looks fabulous.
    Matt
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Quote Originally Posted by grumpiebk View Post
    Your pool builder had Pool Studio all along??? Why in the world did you have me do all of that work?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jun 2016
    FL
    901
    Quote Originally Posted by bdavis466 View Post
    Hi Brian. No, our PB doesn't have it. This was an old rendering from another PB that we did not select. Unfortunately the PB we selected does not have this and is a bit more old school. But we got a lot first hand references for their work.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Sorry if that came off harsh but you wouldn't believe how many times I've been burned by people that were being less than candid .
    -Brian-
    POOL BUILD
    Nov 2014
    Dallas Texas
    165
    Thanks. One day it will be finished.....
    Jun 2016
    FL
    901
    beautiful! What is the width of the pavilion/covered patio?
    No worries, Brian. I am very appreciative of the assistance you provided.
    Nov 2014
    Dallas Texas
    165
    28', you can see the build at the link in my signature.
    Jun 2016
    FL
    901
    Just WOW! I'm dying to see what is going to go on the other side of the pool. And GO NOLES! c/o 2005 here.
    Mar 2015
    Sugar Land , TX
    424
    My grill is also located under a very wide and tall vaulted structure. We installed a vent hood and also 2 exhaust fans in the ceiling above. I should have purchased a stronger exhaust fan for the hood. If we cook alot of smoke producing meats it can smoke us out, even with all 3 vents going.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Quote Originally Posted by rphpool View Post
    We're in a similar situation, but minus the added ventilation. Grill is right up against a big opening, but the ceiling angle really tends to grab the exhaust and can smoke us out with a grill full of burgers.
    We're talking with our pool electrician now about a side project to retro-fit an in-line exhaust fan set up. My original thought was to add a whole house fan right above the grill, but he made the point that it could be pretty loud and recommended looking at in-line fans so the motor could be put in a more remote area.
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    Jun 2016
    FL
    901
    Thanks Plat. We will have 3 outdoor fans with 10k cfm each. They will put off some serious air. But I also don't want to blow the grill smoke back into the patio. I like the idea of the exhaust and it will save a lot of money doing it during roofing construction on the patio. The only problem is we aren't doing the ODK with the pool and not sure exactly where it will be located yet. Hopefully once they start excavation we can get a better feel for the space.
    Brian - UNDER CONSTRUCTION: 17K gal SW Gunite IG. 17'x23'(w/shelf)x34'. 650sf. 114' perim. 3.5'-5' depth sports pool. 7'x11' sun shelf, 6'x8' spa. Intelliflow VSP, IC60 SWCG, CC420 filter, 4 LEDs (2 Globrite and 2 Intellibrite). Hayward 140K BTU heat pump. Pentair EasyTouch 8 automation. Ivory travertine deck. 8"X16" travertine coping. NPT lightwaves Aquamarine spa tile and marker tiles. Undecided on plaster/pebble finish.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    I don't think smoke will be any concern with that much air flow.
    -Brian-
    POOL BUILD
    Jun 2016
    FL
    901
  20. Back To Top    #20
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Just to elaborate more on our build and situation. We don't have jumbo ceiling fans, but we do have 2 moderately sized ones located at the highest point of the ceiling. When the ceiling catches grill smoke, the fans actually make things worse by forcing the smoke down... I think direct outward venting is really the best solution in most cases if it's possible.
    plat.
