Results 1 to 10 of 10
Thread: Finally starting to take care of my pool, just got test readings
    May 2015
    Burbank, California
    66
    I have a Taylor test kit 2006 and these were the readings, i did multiple tests on a few.
    Chlorine 6.2 ppm (31 drops x 0.2 ppm)
    Combined 0 (5 drops didn't change the color)
    pH is at 8.0
    Acid 5 drops to get back to 7.4 pH
    Alkalinity test1: 21 drops, test2: 23 drops. ~~220 ppm
    Calcium test 800 ppm..
    CYA 80?? I don't really know on this one. Pretty sure it's like ~80-+ maybe
    And we currently having problems with yellow algae forming at the bottom near the shaded parts of the pool. I can easily sweep it off. But it does come back shortly after.
    From what I gather. I removed the tablets we have in the pool because the chlorine level is so high. I need to add 30 oz of Muradic Acid (31%).
    Any recommended course of action, which steps should I take first, second, third and so on?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,459
    Re: Finally starting to take care of my pool, just got test readings
    Sickest,
    Well, with your CYA being 80 or 90, you really must keep your Free Chlorine (FC) level above 6 or 7 ppm at all times, not just every now and again. Assuming your CYA is actually 90 you need to target an FC level of 10 ppm, and never let it fall below 7. See Chlorine CYA Chart
    I show you need to add 44 oz of MA to reduce your pH to 7.4.
    While I applaud removing the tabs, which is a great idea, the reason you want to do this is because they are the reason your CYA is so high. Your chlorine level is actually too low and that is why you are fighting algae.
    May 2015
    Burbank, California
    66
    Ok so just dumped 1 gallon of liquid chlorine. And 36 oz Of muratic acid
    Should I wait a day. Or add another gallon of liquid chlorine
    Jul 2014
    Bedford, TX
    7,459
    Well, a gallon, depending on the strength, should bring you up to 10 ppm. So, I'd wait until tomorrow morning and retest and see where you are. Then I'd use "Pool Math" (See top of page) and see how much more, if any, you need to add.
    Same goes for the pH.
    I'd keep that up for a day, or so, and then do an OCLT. Overnight FC Loss Overnight FC Loss Test
    Once we know the results of the OCLT we can determine what to do next.
    May 2015
    Burbank, California
    66
    OK, so I just tested again.
    Chlorine 10-11 ppm
    pH 7.8
    Alkalinity 220 ppm
    Is it ok that my alkalinity is so high? From what i'm reading, it's dangerous if the TA is too low. Then the pH can swing quickly.
    What can I do to lower the calcium levels from 800? because we not allowed in my city to replace pool water. Is there something I can add to reduce these levels? Is 800 ppm a problem?
    23,000 Gallons Plaster Pool & Spa (1989). Hayward Super II 1.5 HP Pool Pump (Single Speed). Cartridge filter. Kit Tester: Taylor K-2006.
    Aug 2016
    New Haven CT
    62
    FYI,
    I had CYA of 90 a couple of weeks ago. I dumped water out of the pool about 3 -4" at a time and filled back with fresh tap water. I did this 4-5 times and my CYA is now 50-55 and have been able to hold FC around 7. I am new to this as well and since we only have about 3 weeks left of pool weather so that is how I'm going to leave it till next Spring.
    Gary
    New Haven, CT
    16 x 32 x 8 in-ground vinyl , sand filter
    22,000 gallons
    Leslie test kit, TF100 test kit
    May 2015
    Burbank, California
    66
    you live in New Haven, CT. Where i'm sure there isn't a water shortage.
    In California, our city would go ape sh1t.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by SickestGuy View Post
    In California, our city would go ape s**t.
    Very true.
    Have you priced a RO treatment (Reverse Osmosis) to remove some of your CYA & CH? Your CSI right now (at 84F) is a 1. This is a hostile environment for your plaster & equipment, and it is very likely that calcium scale will/has began to form.
    Your CSI should be in the -0.3 to 0.3 range, have a read here for a bit more info.
    http://www.troublefreepool.com/threa...turation-Index
    http://www.troublefreepool.com/threa...s-(LSI-and-CSI
    To get your CSI I put all your test results into Pool Math and used 84F for the temp.
    I'm not an expert in plaster, but there are ways to manage this. If you lower your TA to 100, and keep your pH at 7.4 your CSI moves to 0.25 at 90F, close to the upper limit, but much better than a CSI of 1. If you continue to lower TA to 80, your CSI will be 0.1. These CSI values are with your current CH & CYA levels.
    Here is how you lower TA:
    http://www.troublefreepool.com/conte...tal-alkalinity
    Have you tested your fill water? I bet it has high CH & TA as well.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Aug 2016
    New Haven CT
    62
    Yes it depends on what part of the country you're in, no question. We are starting to see some water issues here as well. Nothing like the West coast but certainly not normal. We pay about $4 100ccf or 748 gallons a real bargain compared to oil or gas these days.
    Gary
    New Haven, CT
    22,000 gallons
    May 2015
    Burbank, California
    66
    The yellow algae isn't reforming in the same places anymore, after I did sweep them from their normal locations to the bottom of the deep end, you can see a yellow spots near the intake at the deep end. Will it take time for those to eventually go away? or what do you guys think?
    Should I use Yellowtrine to fight off the remaining yellow algae or shock the pool? Or just keep the chlorine levels high. Right now the pool chlorine levels are at 12.5 ppm.
