Thread: Pool equipment in the shade?
    Mar 2015
    Melissa, TX
    6
    Would this help with high pool temps?
    Our pool is shaded after 4PM but the equipment gets full sun most of the day.
    Your thoughts? I may build a pergola over the equipment pad.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    Re: Pool equipment in the shade?
    No, there isn't enough surface area in the above ground portion of the plumbing to heat the pool.
    With that said, it's a great idea to have your equipment sheltered from the elements to promote longevity.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    What bdavis said ^^^
    You can try cooling off the water by using your fountains or jets. If you dont have any fountains / jets, you can incorporate them cheaply using one of the implements that connect to your return. Many different models on Amazon.
    Not sure how much this will lower your pool temp, but aeration can also increase pH of the water.
    Our pool becomes warm too but we like it that way
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
