Results 1 to 14 of 14
Thread: Test results, test results, test results
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Drained my pool 75% to clear out Uber high CYA levels. Refilled the pool, and added 2 gallons of 10% chlorine. 8 Oz by volume of dry acid and 8 Oz 31%muriatic acid.
    FC 2.6 CC 0.0
    PH 8.0 still
    TA 230
    CH 40
    CYA 55
    Going to get 2 bottles of muriatic acid(per Dave S.), and probably 5 more bottles of chlorine. Hopefully that will be enough to get me through til tomorrow.
    Louise S.
    15,000 gal, 24 round, AG pool, waterway FC 125 cartridge filter, waterway /millennium 2 HP, 2 speed pump, model SD-20-2N11MD. Water is well water ph 8.4, TA 270, CH 20, no metals, lots of tannins
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: Test results, test results, test results
    Ok Louise- lets get that FC up to at least 7 (7 being ideal, 5 being the basement minimum for your CYA of 60) per the CYA chart --> FC/CYA Chart
    Keep going with the muriatic acid until you get a reading in the 7s.... you may have been well higher than just 8.0 and it takes a lot to move it. It will also help lower your TA if you can drop the pH to 7.2. A high TA pulls the pH up, so you do want to lower that. Short read-->Pool School - Lower Total Alkalinity
    Keep us posted how its going
    Yip
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Ok, I think I got some old bleach from Home Depot. This bottle gave me a much bigger jump!Attachment 53661
    FC 5.2
    PH 7.2!!!!!
    Dave S. Told me to aim for 10.0 FC because of the tannin load in my well water. So I am going to bump it up to that.
    Dave S told me to head for 10.0, so that is what I am doing. I have tannins such that I couldn't see the bottom of the pool when it was filled.
    Louise S.
    Jan 2012
    7,373
    Oh lordie, i never suggest that anyone buy bleach from Lowes or Home Depot. They tend to store it outside in the garden center where the sun and heat do a number on the potency.... and they don't have fast enough turn over in stock for my comfort. Stick to Wallyworld or the local market where you know its being re-stocked often and kept inside.
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Ah, good to know! I try to stay away from Wally World, but if it saves me money I will do it!
    FC 9.8
    CC 0.4
    pH 7.4, but I read this one inside and the 7.2 outside, will check again in the AM.
    TC 210
    Pool is definitely clearing up. I am excited to see what it looks like in the AM. Oh dang, gotta go turn off the automatic timer, don't want the pump to shut off tonight!
    Louise S.
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Currently in South Louisiana there is a run on bleach! I saw HD putting up a display of $2.99 bleach for $5.97. If I thought the state would do anything I would turn them in for price gouging!
    Louise S.
    Aug 2014
    Northern IL
    4,615
    Btw, use a 10ml water sample for your FC/CC tests. Then multiply the drop count by 0.5 or divide by 2. It will save on reagents.
    Also, check the date code on your chlorine. 16218 would be the 218th day of 2016. Buy the freshest you can.
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Oh, good to know.
    Morning levels
    FC 8.2
    CC 0.2
    PH 7.4
    Pool looked green, not algae green, more likee blue and yellow make green! Tannins are finally yellow!
    Dumped in 1 gallon 10% and retested.
    FC 12.0, finally remembered the 10ml test!
    Afternoon check
    FC 5.5
    CC 0.5
    PH 7.4
    Pool looks almost see through. Still some tannins left, but not much.
    I keep getting stuff that looks like algae, but I know it can't be, dropping out and getting deposited in the middle of the pool.
    I used my aquabot rover to clean it up. I will pull him out and give his bag a good cleaning.
    Louise S.
    Aug 2014
    Northern IL
    4,615
    Quote Originally Posted by Squeazer View Post
    Dave,
    I truly expected the tannins to clean up much sooner. I finished filling Sunday at about noon and I think it will be Tuesday AM before I have gotten them all out. When they installed th pool I wasn't here, so I don't know if the granules cleaned it up sooner. I will ask and report back.
    What granules?
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Marian;
    The di-chlor granules from the pool store.
    Ok, this morning the pool was sparkling and clear, nothing on the bottom for once either. The test results for this AM:
    FC: 10.0
    CC: 0.0
    PH: 7.5
    Looking at the Chlorine/CYA chart it looks like I should target FC = 7?
    If tonight's test is below 7.0, add to keep it at 7??
    I will keep an eye on PH as it is climbing as well, from the high TA?
    Louise S.
    Aug 2014
    Northern IL
    4,615
    With a CYA of 60, yes, your target is 7. Was all the dichlor dissolved when you tested for CYA? If you're unsure, check it again next sunny day.
    Yes, add back up to 7 as necessary.
    Once everything is settled, you can try to figure out how to aerate your pool to help lower your TA. There are some ideas here: Pool School - Lower Total Alkalinity
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Quote Originally Posted by MarianParoo View Post
    I got into the mess because I was using dichlor, no longer using it!!
    Louise S.
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    OK test results tonight.
    FC 4.6
    CC 0.0
    Ph 7.7
    Added chlorine to increase to 7.0 and acid to bring pH to 7.2.
    How did you add muriatic add without dying?
    Louise S.
    Aug 2014
    Northern IL
    4,615
    Ha! I never measure MA. I guesstimate, make sure I am upwind, hold my breath, and make sure I am prepared to jump into the pool with eyes open if a random drop gets behind my glasses. It's brutal stuff. Please also wait 30 minutes between chlorine and MA additions. Those two chemicals don't like each other!
    FC 4.6? You forgot the 10ml sample again.... Haha!
