Thread: Whrry Whiny Pump
    May 2013
    Fort Lauderdale, FL
    34
    Whrry Whiny Pump
    Hello all!
    My pump motor, a Jandy Stealth, is now whining and whrring. It is intermittent, as in whrrr, then not whirr. Then back again. The water is circulating.
    My intuition guides me to the bearing. Anyone else have other ideas?
    11,800 gallon diamond-brite in-ground pool with second-level 5 ft. diameter spa.
    Jandy DEV48 D.E. filter / Jandy AquaPure 700 SWG with AquaLink RS and PDA Controls
    Jandy Stealth SHMP 1.5 pump / Jandy EEiT EE2000T Solar/Electric Heater.
    TF-100 Test Kit with Taylor K-1766 Salt Test
    Pool is inside a screened enclosure in South Florida.
    Jun 2016
    Oklahoma City, OK
    49
    Re: Whrry Whiny Pump
    It most likely is the bearing or the winding, you can take the pump motor to a motor shop for servicing
