Results 1 to 8 of 8
Thread: TF100 Testing Confusion
    Cuzmail's Avatar
    Aug 2016
    Needville area of Texas
    23
    Received the test kit Thursday and have been playing since.
    Confused on a couple of things.
    1) TA test: My chlorine is high. The test instructions include a note that says "In the presence of high Chlorine, initial color may be blue and shift to yellow. The test is still valid". What does this mean? It will not turn red? The change to blue is the amount of drops to record. Record the number of drops when it changes to yellow? Keep going until it eventually turns blue, yellow, and then red?
    2) CYA test: See a couple of other threads on this one. So far, my kit doesn't have a standard like others have noted. It also doesn't include having sunlight as a requirement to read. Seems a little like an educated guess. Does anyone have any pictures of what "no longer seeing the black dot in the bottom of the tube" should look like?
    Anyone have some helpful insight?
    50,000 gallon in ground plaster old school wonder. 4' to 12' depth with a 7' round spa.
    Cuzmail's Avatar
    Aug 2016
    23
    Re: TF100 Testing Confusion
    Somebody? Anybody?
    Aug 2016
    phila/pa
    4
    For #2: Here is a video Testing Cyanuric Acid with the TF-100 - YouTube that I watched.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Quote Originally Posted by Cuzmail View Post
    Have you done the TA test yet? How did it look? I've never had mine be different than the original green and turning to red with the number of drops, so I'm not sure if yours reacted differently. But the main thing to keep in mind with the test is that you are looking to the color to change and add drops until the last drop causes no further color shift and subtract that last one from your count. Practice will give you the familiarity after time such that maybe you recognize that final color shift.
    The CYA test is indeed subjective. Testing and experimenting has shown the test to be most accurate testing un full sun with your back to the sun. Because your eye gets trained on that dot, I've altered to filling the view tube to the different markers while not looking at the dot. For example, I might fill to the 80 mark then look into it for the dot. I still see it, so I look away from the dot and fill to the 70 mark and look again. I've found this helps me not imagine I'm seeing the dot.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Cuzmail's Avatar
    Aug 2016
    23
    Thanks for the reply AimeeH. I have done the TA test a few times and the results are similar.
    The color changes from green to blue to yellow. This happens when Chlorine levels are high. My question is should I record when it turns blue, yellow, or keep going until it eventually turns red?
    Nice tip on the CYA test. Thanks
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    When the reagent drops no longer cause any color shift.
    Check this. Pool School - Total Alkalinity
    Step 5-2
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here are the more detailed test instructions, Pool School - Extended Test Kit Directions
    Here are some pics of the cya test, https://www.taylortechnologies.com/C...P?ContentID=44
    Cuzmail's Avatar
    Aug 2016
    23
    Thanks! That is the type of clear written instructions I needed.
