Results 1 to 13 of 13
Thread: Squeazer
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Squeazer
    Hello all, I got taken by the pool store this season trying to deal with algae as a result of high CYA levels. I drained the pool yesterday and am now filling it with my well water.
    The well water has no hardness, no metals, but very high tannin levels.
    i have a 15,000 gallon 24 ft round above ground pool. FC 125 cartridge filter, 2speed pump and I am using the Taylor K2006 test kit.
    As soon as the pool finishes filling I will post chemical readings, but a quick test just now shows CYA at 80. So draining and refilling seems to have helped, as the reading before was off the charts high.
    30,432
    Re: Squeazer
    Welcome to the forum.
    How full are you? 50% full means your CYA will be 40....that's good. 98% full means your CYA will be 80 ppm....not good.
    Since you have a K2006, please post test results of your well water for CH, pH and TA.....You'll want to know that.
    How did you test for tannins?
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    Re: Squeazer
    How much water did you drain?
    Fresh well water should not have any CYA in it.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Re: Squeazer
    Dave,
    I will go test well water now. Tannins were tested with professional water test. My drinking water looks like weak tea in a clear glass, so I know it is an issue and here in this part of south Louisiana it is a known issue as well!
    I have about 25% of the pool to fill when I did the CYA test at 80.
    Ron,
    I drained my pool because of the dichlor I was adding. It was off the charts high, drained approximately 75% of the pool water. I was kinda freaked out about draining any more as I didn't want to mess up the liner. I know I may have to do a partial drain and refill again if the CYA is still too high.
    Off to to test well water!
    30,432
    Re: Squeazer
    So, your CYA should end up around 60 ppm. Just a touch high for manual chlorination but very manageable. Use Clorox for FC.
    The FC should likewise take care of the tannins....keep FC up around 10 ppm until your pool is crystal clear.
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Re: Squeazer
    Ok, well water test
    ph: off the charts high. Professional test said ph was 8.4, based on what I saw that makes sense.
    TA: 250 when no green color was evident, 270 when sample wouldn't turn more red.
    CH: 20
    30,432
    Re: Squeazer
    Go ahead and purchase 2 gallons of 31% muriatic acid. You will need almost all the first one to get pH down around 7.4 and then the other one will be on hand as you will have to lower pH periodically.
    Is the water in the pool clear? If not, got a pic?
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Re: Squeazer
    Dave,
    I haven't put put anything in the pool yet. So the pic in the post is with all the tannins!
    Test results
    PH 7.8
    TA 230
    CH 40
    CYA 55
    I added 162 Oz of 10% bleach, calculator called for 196 Oz, saw somewhere it said add a little less and retest.
    Also added 8 Oz dry acid and 8 Oz 31% Muriatic acid.
    I will retest in 30 to 40 minutes.
    Louise S.
    15,000 gal, 24 round, AG pool, waterway FC 125 cartridge filter, waterway /millennium 2 HP, 2 speed pump, model SD-20-2N11MD. Water is well water ph 8.4, TA 270, CH 20, no metals, lots of tannins
    30,432
    Re: Squeazer
    What was the result. I do not recall working to remove tannins before so I am very interested in your progress.
    Aug 2014
    Northern IL
    4,615
    Re: Squeazer
    I am interested too! Btw, with your FC additions, just go ahead and add what PoolMath says. We go slowly with other chemicals, but on chlorine you're fine.
    Aug 2014
    Northern IL
    4,615
    Re: Squeazer
    I am following your other thread now:
    Test results, test results, test results
    Squeazer's Avatar
    Aug 2016
    Lacombe, LA
    21
    Re: Squeazer
    Dave,
    I truly expected the tannins to clean up much sooner. I finished filling Sunday at about noon and I think it will be Tuesday AM before I have gotten them all out. When they installed th pool I wasn't here, so I don't know if the granules cleaned it up sooner. I will ask and report back.
    Louise S.
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: Squeazer
    Please keep in mind that my experience with tannins was with aquariums and was a couple of *ahem* decades ago so there may be better options out there
    The chlorine should precipitate the tannins in your water so they can be cleared out. I just used to put in a shock level dose, pour the clear water off and then remove the chlorine and it worked well.
    You could use a bucket test, ie put some pool water in the bucket and see how much chlorine it takes to precipitate it out in the bucket and then scale up for the pool. At least it may give you an idea of how much longer it may take
    I also used a activated charcoal filter with good success, probably not effective in such large amounts needed for a pool though
    However if you do run into a problem one of the more chemically experienced people here should be able to help
    This article may give some pointers to them (I have to admit I dont understand it) http://www.wwdmag.com/membrane-techn...tannin-removal
    Not sure if any of this is any help but I wish you luck
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
