Thread: Is my skimmer too low?
    Jul 2016
    Rancho Cucamonga, CA
    231
    You guys are always helpful in your opinions... what do you think? It just seems like once the tile is in place, that if the pool is ever more than full above half of the middle of the water tile that it will not work properly? I'm not sure how low the tile sits below the coping, but it just doesn't look right to me.
    Thanks again.
    Pool-15x31', Spa-7x9', depth 3.5-6', HP Pentair Whisper Flow pump/motor, Intelliflo 8-160, 4-to-8 speed, Pentair 320 Clean and Clear capacity filter (upgraded to 400,000BTU stackless heater). Stacked stone- Autumn Rose Classic, tile- Ridgeline Blue Slate, coping- Turning Leaf Quartzite. Start date 7/12/16! Progress thread
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,534
    Re: Is my skimmer too low?
    Your skimmer looks pretty much like mine. They are not done.. When they add the tile to the sides and bottom, I believe that it will be just fine.
    I suspect they have put in a few skimmers before and know what they are doing.
    Jul 2016
    231
    A couple of reviews on yelp of my PB have stated their skimmer was installed too low. So, I want to make sure I'm doing everything on my end to assure it's right.
    Jul 2014
    Bedford, TX
    7,534
    Makes sense.. on mine, they added about 2" of mud on the bottom and then slopped the tile down to the skimmer. It would make sense to just talk with your PB and let him put your mind at rest. It would also not hurt if it were possible for you to be there when the tile is being installed.
    I was personally amazed as to how the various trades building my pool always did things that allowed the next team to just continue along without having to go back and do something over. A very simple example: When they bent the rebar that was to tie into the decking up. I thought how can it possible tie in if it is pointed up in the air. But, when the decking crew came, it allow them the access to do all the deck drains and get their rebar in and everything prepped. Once that was done, the decking crew bent the rebar back down and tied it in the decking rebar. Not that we didn't have a few issues, but for the most part, the various crews worked flawlessly together.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Just figure where 1/2 way to 2/3 up in the skimmer opening is and that's going to be where your water line is. Looks about right to me.
    Solar Blanket, Well Water, Borax Added. 68
