Results 1 to 20 of 20
Thread: How to improve water quality quickly after a SHOCK?
    Dec 2015
    San Jose, CA
    31
    Hello
    During my recent water testing, I was so surprised to see CYA was over 100. I really don't know why because I stopped using Tabs months ago, and the rest 4 chemicals I have ever put into my pool so far are:
    1) (powder) Granular of LeisureLiving, 99.3% of Sodium Dichloro-s-triazinetrione dehydrate, relevant amount used every week after a water test.
    2) Chlorinating Liquid of KEMTEK, 10% of Sodium Hypochlorite, relevant amount used after a water test, only used about 4 or 5 times when needed, all before I had received the Granular.
    3) (liquid) Muriatic Acid of KEMTEK, 14.5% of Hydrogen Chloride, relevant amount used after a water test, only used about 2 or 3 times when needed.
    4) Regular 20 Mule Team Borax, relevant amount used after a water test, only used 3 or 4 times when needed.
    That is, none of above 4 chemicals has anything to do with high CYA, right? And in last 2 months, I only put Granular powder into the pool since other chemicals were balanced.
    A little more contexts: I had my vinyl replaced in mid of last Dec, so I had the opportunity to start with a whole pool of fresh water. I know certain CYA is "helpful" to hold chlorine accountable, so at the beginning, I used the 3" Tabs of aqua chem, which had 94.05% of Trichloro-s-triazinetrione. When CYA reached about 50, I stopped using it, it was in this Apr timeframe or so. I didn't test CYA anymore without Tabs.
    I tested CYA twice in last 7 or 10 days, I really don't understand why CYA is 100+. How could that be? My latest water test result in this morning:
    FC: 17
    CC: ~0
    PH: 7.3
    TA: 70
    Cal. Hardness: 110
    CYA: 100+
    Thank you!
    Kevin
    10,200Gals, 10X34, 3'-4'4'' deep, rectangle in-ground vinyl pool; Solar cover;
    3/4HP Advantage pump; CC150 Pentair cartridge filter;
    NC22 SmartPool Smart-Kleen robot; and a 2-wheel PoolCleaner of HAYWARD
    Tailor K2006 test toolkit;
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Why is CYA so hight?
    #1 is your answer. It contains CYA.
    Dec 2015
    San Jose, CA
    31
    Hello
    I shocked my pool last week due to algae for the first time, now the water quality is getting much better, and close to the level before the algae effect, but it is still a little “cloudy". Well, I am not a patient guy, so are there any ways I can quickly have a "crystal" clear pool of water again?
    The latest water test result in this morning is below:
    FC: 17
    CC: ~0
    PH: 7.3
    TA: 70
    Cal. Hardness: 110
    CYA: 100+ (I have posted another thread about this issue)
    So far, I mainly use Granular of LeisureLiving (powder), 99.3% of Sodium Dichloro-s-triazinetrione dehydrate to do the regular water clean every week. Should I add anything else to speed up the cleaning process? I saw some Ads about coagulant and other pool chemicals. But I am reluctant to put some chemicals I don't know into my pool, and the possible chemical reactions could worsen the water quality or even damage the vinyl/pipe/pump/filter cartridge etc.
    Thank you!
    Kevin
    Dec 2015
    San Jose, CA
    31
    Sorry, I am not a chemist. I was told that as long as it was sodium based, it should be good to use. So, my questions are:
    Q1: Does it mean I must stop using #1 now otherwise CYA keeps getting higher?
    Q2: Any suggestions for an effective alternate which does the most chlorinating job?
    Thank you!
    Kevin
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    No powered potions are ever as good as liquid chlorine. Either bleach or other liquid chlorine is all you should ever need. No reason for weekly 'shock' if you are maintaining the proper CYA/FC ratio as shown in the Pool School chart.
    Using Pool Math shows that for every 1.8ppm of chlorine you were adding 1.6 ppm of CYA. using the Sodium Dichloro-s-triazinetrione dehydrate.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Re: How to improve water quality quickly after a SHOCK?
    The only thing you ever regularly put in your pool is bleach or liquid chlorine. Any magic powder or elixir is just costing you $ and causing the issues you are seeing. As noted in your other thread.
    You just need to keep the FC up and the SLaM level and wait it out while your filter does it's job. You could remove the cartridge and give it a good cleaning just to be sure it's doing it's job to the best of it's abilities.
    Oh and you are going to have to dump at least 50% or your water and add new, so I wouldn't even think about anything else until you do that.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Oh and you are going to have to dump at least 50% or your water and add new, so I wouldn't even think about anything else until you do that. Just to maintain a clean pool is going to require a minimum of 7ppm FC and you really should be up around 12 or more. Until you know for sure how high you cranked your CYA you really can't say for sure.
    38,301
    Stick to liquid chlorine.
    Replace water to lower the CYA.
    Follow the SLAM process.
    There is no need for a weekly "shock" if you maintain proper chlorine levels and follow the methods we teach here.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    More here about different types of chlorine, Pool School - How to Chlorinate Your Pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    That Dichlor you have been using contains even more CYA per unit of FC than the dreaded trichlor pucks do. Trichlor pucks add about 2 parts CYA for every 3 parts FC they add, vs Dichlor which adds close to 1 part CYA for every 1 part FC.
    Actual numbers are something like 11 FC to 6.6C YA for Trichlor pucks and 7.7 FC to 7 CYA for Dichlor.
    Dec 2015
    San Jose, CA
    31
    Thank you every one for your replies.
    I find in a long term, the total cost of using liquid chlorine is not very low, neither the bleach or other liquid chlorinating, because the active/effective ingredients of Chlorine is not very high, like ~10%. I thing everything has its own pros and cons, but I will stop using powder Dichlor from now on, and will replace water to lower CYA later.
    38,301
    But you need to look at the cost of a ppm of FC for each source. Bleach is generally the lowest ... especially when the negatives of the alternatives are considered.
    A pool needs to have 2-4ppm of FC added every day, regardless of the source. Bleach has no side effects other than transportation efforts and disposal of bottles.
    Aug 2014
    Northern IL
    4,615
    This can be a handy tool for shopping for liquid chlorine/bleach. I have it bookmarked on my phone while I am out shopping. Just ignore the zipcode search as it is not up to date: Chlorine Price Per Ounce Calculator
    Dec 2015
    San Jose, CA
    31
    Thanks, MarianParoo. Just want to make sure, your tool helps calculate the price per unit (fl. oz), and we don't see what the products are. E.g., Home Depot Brand, it is 1x128 ounce jugs for $2.99, so the $/oz is 0.187, but we don't know what that specific product (brand) is, correct?
    BTW, just curious, does Sodium HypoChlorite (12.5%) work well in pool chlorinating? I don't see this type of product in "Pool School - How to Chlorinate Your Pool", which only mentions Calcium Hypo and Lithium Hypo. And this Sodium HypoChlorite is originally used for chlorinating the water in cooling tower systems.
    Thank you!
    Dec 2015
    San Jose, CA
    31
    Sorry, forget to attach the link, this Sodium HypoChlorite (12.5%) is sold at http://www.chemworld.com/ProductDeta...oductCode=CW56, and used for chlorinating the water in cooling tower systems. Not sure it works in pool, but the ingredient (Sodium HypoChlorite) is the same to other pool liquid chlorinating products.
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Quote Originally Posted by mazhiqiang69 View Post
    . . . this Sodium HypoChlorite (12.5%) is sold at http://www.chemworld.com/ProductDeta...oductCode=CW56, and used for chlorinating the water in cooling tower systems. Not sure it works in pool, but the ingredient (Sodium HypoChlorite) is the same to other pool liquid chlorinating products.
    Yes that product would work great; it's the same as other liquid chlorine products, but it's very pricey at Chemworld. I recently bought 17 gals (17 one gallon jugs) of 12.5% sodium hypochlorite ("Pool Shock") at Menard's for less than $50. At Chemworld 15 gals costs $345. No wonder they offer free shipping.
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    38,301
    Thank you!
    That is liquid chlorine. It is number 1 in the link you posted.
    Aug 2014
    Northern IL
    4,615
    Sodium hypochlorite is the active ingredient in household bleach and in liquid "pool shock". It comes in varying strengths and jug sizes. Therefore it can be confusing to compare prices. The tool helps with that.
    Dec 2015
    San Jose, CA
    31
    Thank you all!
  20. Back To Top    #20
    Jun 2015
    Glendale, AZ
    156
    HASA sells 12.5% Sodium Hypochloite (Liquid Chlorine), I purchase by the case as I use it all the time, sold by many pool stores in my area.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
