Thread: Air buble under liner
    Aug 2016
    El Campo Texas
    18
    Pool has neen installed and working good for 40 days or so, filled it up week after July 4 th weekend.
    kids noticed a air bubble in the level area of the shallow end. We took lots of care to install and get the liner all installed and it was not there for at lease 40 days. Where could that be coming from?
    it worked its way up side but puzzling on why and how it got there.
    New 2016 in ground liner pool, 18x36, 23,000 gallons, pentair 1.5 hp pump, iC40 chlorine generator, sand filter, well water
    Jun 2015
    N Tonawanda, NY
    476
    Re: Air buble under liner
    It may be water not air. Have you had lots of rain recently?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Aug 2016
    El Campo Texas
    18
    Yes
    18" over last week
    Jun 2015
    N Tonawanda, NY
    476
    If the level of the ground water gets close to the level of the pool water then the liner can get loose & you'll get water under the liner. Your pool must have been overflowing.
