Results 1 to 7 of 7
Thread: Jandy AquaPure Tri-Sensor - R0452500 - can't set production rate?
    Was getting the "no flow" with no error codes on a Jandy AquaPure 1400 system. Tried cleaning the filter and the sensor - as well as removing the jumper and hitting the white calibration button on the daughter card to no avail. Ordered a new Tri-Sensor - got the R0452500 model - newer one that doesn't use the daughter card and has the module that sits outside the control panel box. Installation was straight forward - no issues - according to the instructions - and the firmware - i set the control module to Pgm B. The sensor is now getting Flow - everything looks good except - i cannot set the Production Rate on the Control Panel LED - it is stuck at 00% and subsequently the "Cell On" light does not come on. i tried switching to Pgm A - same result. Any ideas? Thanks ....
    17kgal, PebbleTec finish, Jandy PureLink Water Purification, AquaLink RS, Jandy Stealth series pump, Jandy LXi Heater, DEV Series filter
    Re: Jandy AquaPure Tri-Sensor - R0452500 - can't set production rate?
    If the RS is in auto mode, you use the pda or iaqualink. If you put the rs in service mode, you can change the percentage from the panel.
    Support the site
    Thanks for the reply JamesW. So - i switched the panel into "Service Mode" and i am now able to set the production rate - and doing so the Cell On Led came on. Everything looked good. I put it back in "Auto mode" the production rate reads 00% and the Cell On Led is not lit up. On the controller inside the house - i see there is a new option for SWG Production rate - that is set for 40%. I am not sure what i'm missing but it doesn't appear to be working in Auto mode?
    Update - put a call into Jandy Tech Support ..... they confirmed that you are suppose to see the actual production rate when in Auto mode .... as far as troubleshooting the issue - essentially said i needed to call a pool technician.
    Another update - not ready to call a pool guy just yet. The Jandy Tech support indicated i needed to call a pool technician because it was probably something with the main circuit board that they needed to test. Got me thinking - right next to the connector for the sensor on the circuit board is the connector for the Jandy PDA. We haven't used ours in years, however, when i had originally began looking at the problem - i.e. messing with the daughtercard on the original style sensor - i had noticed that the connector for the Jandy PDA had become unplugged - thought i might have done when i was taking the cover off or something - so i reconnected. Was thinking - could it be? Worth a try - so powered off everything - disconnected the connector for the Jandy PDA - and fired it back up. Voila! - now it is working in Auto mode. So - needless to say something not right with the Jandy PDA I can deal with it later main concern at this point is the SWG and it appears to be working correctly. My guess is a pool technician had previously figured it out and unplugged it and never mentioned it to me.
    Jul 2009
    Long Island, NY
    267
    Quote Originally Posted by flyinraptr View Post
    That is Jandy's answer to everything. Quite often, the pool technician fixes the problem by replacing a circuit board using the trial and error method. There is a troubleshooting document floating around the web that has some test procedures. Try Google to find it.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Quote Originally Posted by poolneophyte View Post
    It sure seems that way and i think i've seen the flowchart. This forum has been invaluable as far as saving $$$ and keeping pool technicians honest. Without it you're pretty much at their mercy.
