Results 1 to 10 of 10
Thread: Liquid Stabilizer Okay For Me? - CYA
    I have a SWG system and my CYA is about 20ppm and want to add stabilizer/conditioner to it right away. I used HTH Conditioner (dry granules) before and it took a really long time to dissolve. Will liquid stabilizer like this be safe for my SWG?
    http://www.intheswim.com/Pool-Chemicals ... nditioner/
    Any objections? Thanks!
    Viking Pool - Ceramic Fiberglass - Key West Sapphire Blue - 9,000 gallons
    Aqua Rite Goldline SWG
    Sta-Rite PXC150 Cartridge Filter
    Sta-Rite MPRA6F-148L 1.5 hp Pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Liquid Stabilizer Okay For Me? - CYA
    it's fine...just way more expensive
    You are right. The 4lb HTH granules is about $15 and would raise my 10,000 gallon pool by 40ppm. The liquid conditioner is almost twice the cost.
    Relax, open a bottle of POP (pool owner patience), and use the dry stuff.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Whatever you use, intheswim.com are too expensive.
    Try poolsupplies.com (aka leisureliving.com)
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Guest
    You should also be able to find CYA granules at Home Depot, Lowes, many Ace Hardware, and at your local pool store so shop around a bit!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yup...Walmart carries HTH products at a pretty decent price.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    By far, shop around. I've seen all sorts of prices, AFTER I bought mine for $14/3 lbs at the Pool Store.
    I saw $15/4 lbs at "Meijers".... I saw $9/2 lbs at a different Pool Store.
    One thing I noticed.....never paid attention before as I never had to add it....
    The Malibu brand I bought, only had 50% CYA- the rest was Sodium Bicarbonate... I looked on the bottle after noting the price on the other 2 lb bottle and the ingredient said 99% CYA...I went home and looked at mine, because I couldn't believe the one pool store would have such significantly different pricing....
    I wish I was paying attention when I bought it. Old habits die hard....something about being in the pool store made me a sheep again.....(and it explains why I had to use more than I thought I would to reach 50.)
    I purchased a 4lb container of stabilizer for $14.97 + sales tax at Lowes. It contains 99% cyanuric acid.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by frustratedpoolmom
    Too funny
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
