Thread: Problem with the quick connection of a Polaris 380 robot
    Aug 2016
    Jacksonville FL
    1
    Hi all,
    I have just bought a house and cleaned the pool. I am a novice in pool taking care of. I have a Polaris robot. My problem is that when I plug it in the pool the quick connection is not staying, it doesn't stick to it due to the pressure of the jet. There seems to be no problem with the plug itself, it doesn't seem to be broken at all. The Robot seems to be in pretty good shape.
    Anyone would see where the problem could come from? Thanks in advance for your advices.
    Marc
    Apr 2015
    tucson, arizona
    1,107
    Re: Problem with the quick connection of a Polaris 380 robot
    This has a quick disconnect that is pushed in and turned clockwise to lock in, pull on it to see if its secure. If this doesn't work unscrew fitting in wall and check to see if there are two little nubs sticking out that accept the disconnect
    Jul 2016
    East TN
    45
    As a side note to kadavis, you could turn off the pump when trying to plug it into the return port. It can be troublesome to do it with all that pressure coming out.
    18x36 8ft deep end (~27k gallons), IG, Vinyl Lined, Polaris 360 Cleaner
    Sand filter, 2HP Pump, Municipal Water Source TF-100 Test kit
    East TN
    CYA Chart SLaM Add DE to Sand OCLT
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    We use a Polaris quick connect wall fitting and learned you can't really trust the connection if you try to put it on while the pump's running. Gotta turn that pump off to get the fitting to click in place. Sorry!
