Results 1 to 10 of 10
Thread: Can I let the pump motor run 24/7?
    Apr 2010
    Syracuse, NY
    103
    We sold house/pool, and I'm maintaining the pool until closing in 2 weeks. Our pump motor is old (original equipt about 15 years old,), and this am when I went to turn it on, the motor didn't engage, and I heard a humming sound. I immediately turned it off, and tried it again, and it started ok. I then turned it on and off a few times and there was no problem. So now I'm nervous about leaving the pump off at night, is it ok just to let it run all the time? Thanks, Ed
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    30,426
    Re: Can I let the pump motor run 24/7?
    Yeah, they are pretty durable and designed to run for a long time. You'll suck up a lot of electricity and could maybe fix it cheaper by replacing the start capacitor.
    If you are electrically clueless as I am, you might know a friend to help.....it is a pretty easy job and that is likely to be the cause.
    Let me change my mind.....for two weeks of run time, I would let the pump run and tell the new owners. It is not an expensive fix if that's the cause.
    Donldson's Avatar
    NW Ohio
    2,904
    My father's single speed pump has run non-stop every Summer for the past 15 years and is just now showing signs of needing replaced, so yes it should be just fine.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2010
    Syracuse, NY
    103
    Thanks for all the replies. The start capacitor looks like a fairly easy fix, there's a couple of nice youtube videos on it. Am sure I could do it, but why risk a bigger problem at this point. I like the idea of just letting it run for now.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    They can run 24/7. The pump will be fine, your power bill wont be so good.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by edweather View Post
    Usually, when a start capacitor goes bad, the motor will never start. If it is intermittent, it sounds more like bad bearings. Is the motor louder than normal?
    Mark
    Apr 2010
    Syracuse, NY
    103
    Motor doesn't seem louder than normal. Maybe it was just a one time thing, but not likely. Problems never seem to go away once they start Just going to leave it running for now and hope for the best. I was originally thinking it was like when a starter in a car goes bad, the brushes or whatever get worn, and you can rap the starter with a hammer for while to get it going.
    mas985's Avatar
    Pleasanton, CA
    11,741
    That analogy sounds more like bad bearings in a pump motor. They get a little rusted/frozen and a wack with a board can sometimes free them and get it going again.
    Mark
    Sfpat's Avatar
    Jul 2016
    tulsa
    105
    Could be debris in the impeller
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner
    We have been running our (older) pump continuously all summer long. I had intended to get a new variable-speed pump for the summer but ended up being too busy to follow through. I now intend to replace it at the start of the 2017 season. Anyhow, you're fine running it 24/7. The electric bill will be a bit of a shock but that's to be expected.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
