Results 1 to 14 of 14
Thread: I should know better!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    My son had loosened to lid on the pump basket the other day, (one drawback to TFP, the water is so clear the basket looks empty. Hubby thought the same before.) so I closed the valve in the hose so I could reposition it, as it was dripping. Well, I briefly turned the pump on before realizing I forgot to open the valve back up. It was the inlet side. Now the pump is very loud. Is it ruined? It's an Intex Krystal Klear and it was purchased in 2012.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    8,900
    Re: I should know better!
    HOW briefly?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    Not even a minute. And I'm wondering if I should have turned it off before opening the valve. I didn't, though.
    Apr 2010
    East Texas
    8,900
    I can't imagine that causing any damage. Maybe it just needs to "catch up"?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    I'll have my husband look at it when he gets home. I turned it off. But it's definitely the pump making a loud noise, not just the pump basket, etc. It's much louder than the noise it makes when the basket has air.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    https://vimeo.com/179569109
    A short video of the noise. It is normally quiet enough that you can't tell it's running when you are sitting on the deck of the pool, or even in the pool, for that matter.
    It's sucking air from somewhere....probably the lid. Stop the pump, open the lid, check for debris around the lid and lip. Fill basket with water and replace/reset lid. Make sure valve are in correct position, then restart pump.
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    It usually makes a different noise when there is just air in the basket. I had already opened it and tightened things. The air is all out of the basket now, (it always has a bit of air when you take the lid off, then it works it's way out.) It's definitely something with the motor. I back washed earlier. It's still moving the water well, and the return has full strength. It ran for a few hours, still working, but still loud....
    https://vimeo.com/179592241
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    Quote Originally Posted by samiguy View Post
    Sami
    I think you were right, after all! I got a little worried that the ump ran dry for a while when I remembered my son had originally thought the pump basket was empty and took the lid off. It got put back crooked. I noticed it leaking and couldn't get it removed. Had the hubby redo it for me. No leaks. The pump was still making that noise for a while, then it was more intermittent, and eventually stopped all together.
    Aug 2014
    Northern IL
    4,615
    Good news!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    Well, it last another month, then lights out.mthe pump died over the weekend. Looks like I will have to get one over the winter. I'm going to go ahead and close the pool this week.
    pabeader's Avatar
    May 2015
    Dallas Ga
    4,062
    What's the water temp running?
    Bob - Palm Beach by San Juan Pools. approx 5000 gals., Pentair 320 cartridge filter (all new guts installed by me), Goldline SWG, 'New to me' Kreepy Krauly Sand Shark, Intermec 104 Timer Test kit: TF-100 w/Speed Stir
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    It was 65 the other day. I was too depressed (and busy) to look, lol. It had been raining for a few days. I know I probably already have a bit of algae starting. I opened the season this year with a bit because I did not cover it last year. It gave me some real life SLAM experience, lol.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,385
    Went out to take the solar cover off. As I was hanging over the side of the deck railing, I stepped on a hornet. I'm having bad pool karma, ha ha.
