Thread: Problems With Pool 2
    Jul 2015
    Port Angeles WA
    17
    Figured out how to post pictures sort of. The process is very frustrating. Tells me to reduce I do then gives me a different result.
    I was just hoping to please get some design suggestions. Thank you. Have a nice day.
    Hello All. I have not read all the posting rules yet and want to ask a lot of questions but will limit for now. Please let me know if I break a rule by accident. I have been having a lot of troubles. We bought the Intex Ultra Frame Rectangular 24 12 52 in June 2014. It has taken us this long to get it going. We installed electric, made a pump house, built a deck, moved a water line for a hose, and finally on Friday we got the pump going for the first time. We have a series of problems that I was hoping to please share and get feedback. One of the first was that we placed sand and then read the manual and it discourages sand so we removed a lot of it only leaving a thin layer. It was about 2 inches thick. Then we got a Pentair Master Temp 125 heater and discovered how expensive propane is and ended up selling that. Just recently we bought solar panels from Amazon and put those on our roof. Then after almost two years getting close to the finish line I messed up and tossed 6 chlorine tablets in the pool and 36 hours later realized that was a terrible idea and the result was six faded spots. Next we installed the wide mouth hayward skimmer in the wall. That was a nightmare. We had trouble with our screw holes and had to angle our fasteners and they were missing the holes and it took really long to get it seated. As I was working one of the last fasteners the flap of vinyl under the plastic cover ripped (I could hear it) and then finally we got it in place. Later to discover it was not level and it was leaking. After going back and tightening screws most of the leaks stopped. However I still have one screw that I canít get to seat and tighten down. After filing the pool almost to the top our water sprinkler became wedged under the deck and it started digging into the vinyl. Also the blue valve off of the skimmer was angled wrong and it started pushing into the deck leg post. We had to jack up the front legs of the deck one inch to take some pressure off. That valve also had a small leak. So last night we let out water so that the valve and sprinkler pipe would become un wedged. And now I can tell that the pool is hot level either. It was super cool being in the pool with my 9 & 4 year old and I am motivated to fix these problems. I hope it will be okay but I would like to share a few pictures - I made sure I cropped and that they are not too large. If some of you folks might offer some feedback I sure would appreciate it. Thank you. Have a nice day
    Jul 2015
    Port Angeles WA
    17
    Problems With Pool 3
    Very Last picture again my apologies just wanted to make one post with three pictures
    but the process was almost has hard as the pool. Ha Ha. : - ) Respectfully. Have a nice day.
    Attachment 53627
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Problems With Pool 2
    Many folks upload pics to Photobucket, copy the IMG code and paste it in their post, this will embed the pic in the thread.
    If you become a supporter you get more space for pics, CLICK HERE to Become a TroubleFreePool.com Supporter!!
    I find it is easier to set the camera to a good pic size then you don't have to resize pics before uploading.
    DFW, TX
    24,497
    Looks like a nice set up! Here is a build with a similar pool that might be helpful
    New above ground oval 18x33 install
    Jul 2015
    Port Angeles WA
    17
    Thank you for this response. I will try this. : )
