Results 1 to 10 of 10
Thread: Auto Pilot vs. Pentair Intellichlor SWG
    May 2016
    Gilbert/AZ
    16
    So I'm in the middle of a pool build and I open one of the parts boxes left by the contractors. It says Auto Pilot on it. It turns out I got an Auto Pilot SWG with my pool build package. I have a Pentair pump and DE filter and just assumed the SWG was Pentair as well but its not.
    Does anyone have any experience with an Auto Pilot SWG? I was thinking of taking it back to the PB and exchanging it for an Intellichlor but I don't want to have to dish out any more cash if it is unnecessary.
    Any input, feedback is much appreciated!!
    20K gallon IG Ultra Poz plaster, AutoPilot SWG.
    DE Quad filter, Pentair pump.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Auto Pilot vs. Pentair Intellichlor SWG
    The Auto Pilot is a high class SWG as is the Pentair.
    If you are going to install a Automated system then I would suggest the SWG be from the same manufacturer as the system controller.
    Divin Dave,
    Jun 2011
    Long Beach, CA
    2,790
    In other words, if you don't have automation keep the AutoPilot SWG. Those are top of the line SWG's.
    The Pentair SWG's need automation to get the fine control settings that the AutoPilot has without automation.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,533
    Yabruf,
    Your signature says,, Pentair IntelliTouch w/SWG, so I suspect something is wrong. Just ask your PB if this is a mistake, because my guess it is. If it is not a mistake, ask the PB if the IntelliTouch will control the AutoPilot, maybe it will but I doubt it...
    Your signature also says.. Ozone w/ instant frog mineral pack... These systems get really bad press here, so you might want to do some searches on what they can do and what they can't do, before having them installed.
    Your signature does not say what type of pump.. not necessary, just curious.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    My first full year of owning a pool. I have the AutoPilot SWG and love it. It did take me a while to figure out pump run times, and % settings on it, but now its second nature in setting it. Highly recommended by me.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    If I recall correctly, the Autopilot can be controlled by Pentair automation. Let me check...
    http://www.pentairpool.com/products/...systems-79.htm
    See the 7th bullet under the features section on that page. You'll likely have to call Pentair to see how exactly to set it up.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    JoyfulNoise's Avatar
    May 2015
    13,239
    I would say it depends. If your package includes a Pentair IntelliChlor IC60 then that is a 2lb/day chlorine gas cell. If the Autopilot has an RC52 cell, then that's equivalent.
    My point is, you need to make sure you're getting what you were promised and what you paid for.
    Matt
    May 2016
    Gilbert/AZ
    16
    Jim,
    Fixed my signature to the correct swg. Also I plan on holding off on the ozone/mineral pack until I can do some more research.
    Thanks for the tips!
    May 2016
    Gilbert/AZ
    16
    Thanks for the feedback on the AutoPilot SWG. I feel much better knowing that I wasnt given some cheap knock off SWG.
    My initial confusion on the specs was because I thought the pentair pump/filter included the SWG. So I was thinking AutoPilot was the Pentagon brand. But now the setup makes sense and I see how the different components work to gather.
    JoshU's Avatar
    New Orleans, LA
    543
    We do not typically recommend interfacing an AutoPilot system with third party automation systems as you'll disable some of the main features and benefits that make AutoPilot different from the rest of the market. One of these features is temperature compensation which automatically adjusts the output of the system based on water temperature increases and decreases.
    Another factor to consider is the cost of replacement cells. The Pentair IC60 cell has an integrated control board so you are replacing electronics in addition to the cell. A quick Google Shopping search shows prices of $699.99 and $724.00 for the replacement cell. The RC52 can currently be purchased for around $400 after a factory rebate.
    AutoPilot is a US made unit (in St. Petersburg, FL) and they are the oldest US manufacturer of salt chlorine generators.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
