Thread: TF 100 cya question
    Dec 2015
    Newington, Connecticut
    113
    TF 100 cya question
    I'm assuming that the idea is to fill equal parts pool water and reagent in the supplied bottle. Measures out to 15 mil and 15 mil. Is it possible to reduce to half the doses to be cheap or is this the required amounts for the size test tube. The reason I'm asking is that it is difficult to measure the meniscus especially at the top of the bottle. When I measure out two equal portions the bottle fills to the bottom of the neck not the top of the label. Next test I will measure equal parts with a medication cup and then put in bottle.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    38,235
    Re: TF 100 cya question
    It just needs equal parts water and reagent. You may not need the full 30 ml if your cya is not down around 30ppm or lower
