Results 1 to 10 of 10
Thread: cya question
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    cya question
    Hi everyone,
    I've just finished a baquacil to bleach conversion and my water has never looked so beautiful.
    I changed out the sand yesterday and added 3 lbs. of cya in a sock to get my levels up. I went out this afternoon to check it and the sock is already empty. I thought I read it takes a long time to dissolve so I got kind of worried.
    Maybe I just misread. Is it supposed to take a while to dissolve or just a while before it registers your levels?
    This forum has been such a great help, thanks all of you!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: cya question
    Don't worry, that's normal. Usually it'll break down into smaller and smaller pieces as it's dissolving and will escape the sock, but still take some time to completely dissolve and show up in your testing. Go ahead and test it either tonight or tomorrow and see what it reads. I usually give it a day or so after it's dissolved out of the stocking.
    Congrats on your conversion!!
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    NE Ohio
    63
    Re: cya question
    I am currently starting my conversion. I found Gallon Bottles of CYA at the Pool Store for $27.95.
    Is there anywhere else I can find it locally?
    24" Round Above Ground 52" high
    Jacuzzi CFR 100 Platinum Filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: cya question
    some hardware stores and walmarts carry granular cya/stabilzer, but I doubt they carry the liquid kind. you can always check though. the liquid kind is a lot more expensive.
    NE Ohio
    63
    Re: cya question
    I don't have a problem using granular cya, I just wasn't sure where to find it. I scanned the isle quickly at Walmart, but must have missed it.
    Thanks!
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: cya question
    they don't necessarily have it, but the pool store almost definitely will.
    Re: cya question
    Many of the big box stores carry CYA/stabilizer/conditioner in their pool departments, though that does vary somewhat depending on how common swimming pools are in your part of the country.
    Jun 2008
    Carrollton, GA
    88
    Re: cya question
    Hello,
    Wal-Mart carries the stabilizer under the name of aquachem in 3lb containers. It is a purple label and says balane+protect on it. You can also get stabilizer at Home Depot. C.heaper at Wal-Mart.
    Susan
    18x33 AGP, BAQUAPURE 200 lb sandfilter, 2 1/2hp Workhorse pump (2 speed)
    NE Ohio
    63
    Re: cya question
    Thanks, I'm on my way there for more bleach so I will tak a look!
    NE Ohio
    63
    Re: cya question
    Thanks, just found it at Walmart, but in a different container. It still has a purple label on it. 4lbs. for $13.98!
