Thread: New to owning a pool
    Aug 2016
    El Campo Texas
    18
    I live near Houston TX, contractor and can do many things. So i thought lets build a pool. The cost of a gunnite pool added up to a lot so i decided on a liner pool. Got it built and now have issues with keeping it clean from sand and keeping the water levels right. I always need to add acid and add chlorine, and some times salt. Any help will be nice.
    New 2016 in ground liner pool, 18x36, 23,000 gallons, pentair 1.5 hp pump, iC40 chlorine generator, sand filter, well water
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: New to owning a pool
    Welcome to TFP! Congrats on the new pool!
    You need a good test kit, Pool School - Test Kits Compared. I use the TF-100 from TFTestkits.net.
    Do a little reading here
    ABCs of Pool Water Chemistry
    And here
    Pool School - Getting Started
