Thread: Return pressure
    Jun 2016
    Atlanta/GA
    33
    Return pressure
    I had a 200lb ranger series sand filter with a jacuzzi slr 1.5hp pump. The filter starting leaking and a buddy of mine had a hayward pro series S244T 300lb sand filter he was not using. I installed it but now I have a very weak return pressure. The filter pressure gauges reads about 22psi. I backwashed and rinsed after the new Sand was installed. What can cause this?
    Jun 2016
    Atlanta/GA
    33
    Re: Return pressure
    After some more troubleshooting if the selector valve is in recirculation mode the pressure drops to 14 and has tons of return pressure. Now what?
    Jun 2016
    Atlanta/GA
    33
    Re: Return pressure
    Also there is not as much flow when on rinse and backwash as usual.
    24' Round above ground, 52in deep, Cooper Ranger series 200# sand filter, 1.5 hp pump Jacuzzi pump
    Jun 2016
    Atlanta/GA
    33
    Re: Return pressure
    Anyone?
    Jun 2016
    Atlanta/GA
    33
    Re: Return pressure
    I think I am going to try and swap out the laterals from my old filter. The old filter had larger laterals. The new one has the smaller umbrella style.
