Thread: Empty Jacuzzi Water Into Pool
    May 2015
    Burbank, California
    66
    I need to replace a part on the bottom of my jacuzzi, and it would make my life a million times easier if I could empty it first.
    I was talking to a sales guy at my pool store and he said there was a switch that would empty the jacuzzi water into the pool. Where/what would that be?
    Is this possible? If there is no switch, any suggestions on how I can do this?
    23,000 Gallons Plaster Pool & Spa (1989). Hayward Super II 1.5 HP Pool Pump (Single Speed). Cartridge filter. Kit Tester: Taylor K-2006.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: Empty Jacuzzi Water Into Pool
    The only way for us to know this would be to see your plumbing. Can you attach a pic? If not, I suppose you could use a sump pump.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I don't know what setup you have but I have Jandy auto valves that have a toggle switch on the side. In my case the up position would pump the water from the main drains into the pool and close the return in the spa. I think you need to be in spa mode for this to work in my case.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2015
    Burbank, California
    66
    So what should i Do? take pictures of my pool equipment? What do you guys need from me?
    Dec 2014
    Houston, Texas
    134
    What wjr75 said,
    How do you switch from pool to spa? Manual or automated? Short version you need to change the suction from pool main drain/skimmer to spa suction and leave the return valve on pool. If you have a common line (spillover) shut that valve if possible to hasten the process.
    Edit: Or just hook your manual vacuum hose to the skimmer and put the pole with vac head attached in the spa.
