Thread: IC40 Spa Settings
    Apr 2016
    SW Chicago/IL
    56
    IC40 Spa Settings
    I was looking through the ScreenLogic manual at the Chrolinator section and saw under the Pool Output % setting:
    "The IntelliTouch control system will automatically drop the chlorine output levels to 1/20 the output when the Spa mode is switched on."
    If this is the case, what is the Spa Output % setting even for? Is it the % of the 1/20 then? I was just confused when I read this and wondered if anyone could clarify. Thanks!
    15,000 gal fiberglass pool with built in spa and tanning ledge (Leisure Pools Ultimate 35), Pentair Intelliflo VS pump, Intelliflo XF spa pump, Pentair 250k heater, Easytouch 8 with Screenlogic, Pentair IC 40 SWG, Pentair Clean and Clear 420 cartridge filter, 4 GloBright Pool Lights, 1 GloBright Spa Light, Coverstar Auto Cover, Interfab X-treme 2 Slide, 4 deck jets, Dolphin Oasis Z5 robotic cleaner, TF-100 test kit.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,511
    Re: IC40 Spa Settings
    cd,
    In the Spa mode, the IC40's output will automatically default to 1/20th of the Pool percentage, unless you override it, then it will be whatever you set it to be.
    Apr 2016
    SW Chicago/IL
    56
    So the 1/20 is just the initial default and as soon as I changed it, that is overridden? Since it is a spillover spa, wouldn't I want to keep the pool and spa settings the same?
    Jul 2014
    Bedford, TX
    7,511
    cd,
    Kind-of depends on you. While Spillovers look amazing, and are great to impress your visitors, they also can drive pH through the roof due to all the aeration. A lot of people don't leave the spillover running except when they want it to run.
    Also, if you want to use the Spa, with the heater on, then you will dumping hot water into the pool, which I would think would making heating the Spa harder. (I don't have a Spa, so I'm no expert here)
    And finally, if you are in the Spa mode, all the chorine that is generated by the IC40 will be pumped into the confined space of the Spa, where you are sitting. I suspect Pentair designed it the way they did to prevent you from bathing in chlorine.
