Results 1 to 7 of 7
Thread: Am I on the right track?
    Jul 2016
    Highgate
    25
    We bought our house in July with an existing above ground pool (aka swamp). I finally started tackling the thing after feeling encouraged from reading threads on TFP and learning all the things here. So thanks!
    So, I've been SLAMming the pool for a good 2+ weeks now, and it has slowly been looking better and better. But I'm ready for it to be done, and everyone is impatient and wants to swim (2 weeks before that I had been pouring the bleach in, but not SLAMming it, apparently, because I messed up on the numbers, and some no-no things I shouldn't have put in it. I've learned from my mistake. ANYWAY....
    Here I am today as of 1 PM
    FC=19 (It was 19 last night, I added 18 oz of Cal-Hypo before bed to get it back to 24 [I was all out of liquid], this morning much of the cal hypo was still undissolved, and at 9 AM, FC was still 19. I added 18 more oz of cal hypo. Still not all dissolved by 1, but FC still the same. I'm heading to the store to get more bleach in a bit))
    CC=2
    CH=175
    CYA=60
    TA=170
    PH=7.5
    The water is still cloudy, but no visible debris. I've been adding a little DE to my sand filter to help clear it faster, but not appearing to do anything.
    Is there anything else I should adjust at this point, or just keep SLAMming it? (my pump has been working non stop, I'm scared to see my power bill haha)
    Thanks!
    19,000 Gal, Above Ground, Jacuzzi Pump and Sand Filter
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: Am I on the right track?
    Stay the course! Make sure to brush often as well. Are you able to see the bottom yet? Is there any debris down there that could be raked out?
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,254
    Welcome to TFP! If you truly have been slamming for 2+ weeks and have accurate test results, then your pool should be clearing up. What test kit are you using? Here at TFP, we rely on accurate testing and only recommend certain test kits.
    Please explain why you using Cal-Hypo and it is not dissolving. Liquid Bleach can be found locally. Outside of this, regular brushing, maintaining the SLAM level based on your CYA along with regular back washing (when needed) is all that's necessary. Your pool will clear up.
    If your pool filter is slow at moving water, it could definitely take longer than normal. Most pools clear up within a few weeks and make a lot of progress. Once the SLAM is done, you should keep your pool at the minimum FC level and brush often to keep things moving along.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jul 2016
    Highgate
    25
    I can't see the bottom yet, but I let the chlorine drop a little the other day so we could get in it and kick things around just to make sure. I found the skimmer cover we were missing! Lol. But it was very clean, just cloudy. I've been vacuuming and brushing like crazy.
    Jul 2016
    Highgate
    25
    I've been using the TF-100 kit. I actually ran out of the chlorine testing regent the other day so had to order more. Only used cal-hypo this time because it's all I had on hand. I figured my CH was low enough it wouldn't hurt anything. But typically I've been only adding liquid bleach or 12.5%. I just got home so have some more bleach to add. I'm going to go out and test again. But i was noticing the cal hypo didn't raise my fc very fast because it takes so long to disolve.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Liquid chlorine all of the way! Fast and best way to SLAM.
    You should take a picture of your pool looking down on your steps. That will help you see the day by day changes your eyes cannot see.
    Aug 2014
    Northern IL
    4,615
    Should you ever use cal-hypo again, please make sure it dissolves by mixing in a bucket first, brushing until you can't see it, or put it in a sock like you would for granular CYA. It's not good for your liner to have it sit undissolved.
