Results 1 to 8 of 8
Thread: Looking for CYA 50
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    Looking for CYA 50
    I am looking on the tftestkits website, but I am not finding the CYA 50 solution to "calibrate" my eyes to doing that test. Is it still available?
    Kevin
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: Looking for CYA 50
    The reagent you are looking for is R-7065. I don't see it on the TFTestkits.net site though.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    49
    My bad, posted the wrong link
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    Thanks
    TF-100 Testing Kit
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    I could no longer find it on the TFTestkits site either. Did they pull it because it was causing so much controversy here?
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    38,388
    They stopped carrying it. You can still get it directly from Taylor if you want, although the results certainly do not seem to work as advertised
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    I think the more correct statement would be "the CYA test results from many TFP members did not match the advertised 50ppm standard". The problem with the standard 50ppm came in that if we were to believe that the 50ppm sample was truth, then many members discovered that their process, chemicals, or testing equipment were deficient. So this brought up the question of whether the 50ppm sample was truth or if so many members testing were so far off.
    As Jason stated, you can purchase from Taylor Technologies here:
    Welcome to Taylor Technologies
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Here are some pics of what you are looking for in the test
    https://www.taylortechnologies.com/C...P?ContentID=44
