Results 1 to 9 of 9
Thread: 115 or 230v?
    Jul 2015
    Orlando, FL
    26
    115 or 230v?
    So my pump died and I don't know if it was running on 115 or 230? It's on a double breaker, which suggests 230, but the wires are black, white and green, which suggests 115.... The old pump wiring diagram, if I'm reading it correctly looks like it was wired for 230 (high voltage).
    I want to make sure with a volt meter but I don't know how- do I touch both black and white wires with a multimeter to check the voltage, or black to ground? Or....?
    Thanks
    Apr 2013
    Sacramento, CA
    2,769
    Re: 115 or 230v?
    What is coming off the breaker? Trace those wires to your pump.
    Aug 2016
    clovis/ca
    75
    Re: 115 or 230v?
    Yes just make sure your meter is set right and touch black and white. Should give you 230. You can also check individual by touching one of your wires and the other terminal from meter to ground. If done individual both wires will have 115 if it's a 230 system
    Quote Originally Posted by relliky2d View Post
    Thanks
    As a side note if it is 230 then you can wrap the white wire with black ele tape so there isn't confusion in the future
    aprox 18k in ground
    Jul 2015
    Orlando, FL
    26
    Re: 115 or 230v?
    Quote Originally Posted by barnnns1 View Post
    Thanks. Does it matter which wire from meter (red or black) goes to wire to pump (black or white)?
    25,000 gallon inground plaster
    K-2006 test kit
    Apr 2013
    Sacramento, CA
    2,769
    Re: 115 or 230v?
    Woooooh
    The thick red and black wires from the meter go to the panel and unless you are an electrician you should not be touching them.
    If there are white and black wires going to your pump from a two pole breaker then you need to trace back and make sure the breaker wires actually go to the pump.
    As Barnns stated across it should read 230 individually 120.
    Jul 2015
    Orlando, FL
    26
    Re: 115 or 230v?
    Quote Originally Posted by gwegan View Post
    Woooooh
    Not following. I don't know how I can trace the wires when they go underground. I'm not ripping it all up.
    Can anyone review my attachments and verify that the wiring diagram and the matching wiring configuration on the old pump indicates 230v ?
    K-2006 test kit
    Hot6's Avatar
    Jun 2014
    Alabaster, AL
    27
    Re: 115 or 230v?
    Your photos suggest the pump is wired for 230. The picture shows a diagram for high voltage as.... White on B, line1, line2, Brown on A. Line1 and Line2 being the feed from your breaker panel. The photo inside the pump looks like the diagram for High Voltage. As others have said you may want to consult with an electrician just to be safe.
    IG Vinyl 18x36 28500 Gallon SWG Taylor K2006 Test Kit
    380 Gallon Master Spa Chlorine for sanitizer
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: 115 or 230v?
    Woooooh
    You do not seem to have enough knowledge or experience to be performing these tasks. We strongly suggest you consult a qualified electrician to make sure your pool and equipment are safe.
    Aug 2016
    clovis/ca
    75
    Re: 115 or 230v?
    If you are talking about your test meter wires then red is what I usually use for my hot and black for ground.
    aprox 18k in ground
