Thread: How to care for my pool after 10 inches of rain in 7 days
    Jun 2016
    Austin, Texas
    9
    Question How to care for my pool after 10 inches of rain in 7 days
    It goes without saying that my pool chemistry (which I just got all settled and happy a few weeks ago) is now completely out of whack. We have received over 10 inches of rain in the last 7 days and have had to drain the water three times! Today is our ONE dry day before another system moves in over the weekend. Weather promises a dry out after that.
    I know that I will need to add salt, correct the pH and possibly add CYA - my questions are.... what should I do first? And should I do anything today or just wait until the rain is completely gone next week?
    TIA!
    30,000 gallon Salt pool w/spa, sparkle Quartz, pentair FNS Plus filter w/ Ultra UV. Pentair Mastertemp 400 heater, Intellichlor SWG, Pentair Intellifo variable speed pump, Polaris PB4-60 booster pump. Use Pentair screenlogic app. Austin, Texas
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: How to care for my pool after 10 inches of rain in 7 days
    I'll bet you aren't as bad off as you think. But, it's test first, then pH, FC next (in case your SWG hasn't been keeping up), CYA and then salt.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    As Mr. Bruce stated, you will be surprised that not much has changed. If you removed a few inches of water, the drop in your levels will be insignificant to really throw off your chemicals. My pool is half your size and the PH was not affected with a lot of rain. I did drain some water, twice due to heavy rain and have had to add water(a few times this year due to a little evaporation). From what I can gather, only CYA was affected and usually we get enough rain just to keep things moving along.
    If you have test results from before and after all the rain, we would love to see how the rain affected everything. Outside of this, please follow the recommendations in which order adjustments should be made.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2016
    Austin, Texas
    9
    Thank you both.
    Before the rain:
    FC: 4.4
    CC: 0.0
    pH: 7.4
    CYA: 80
    Salt: 2950
    After the rain:
    FC: 6.0 (no idea how this went up)
    CC: 0.0
    pH:above 8.0
    CYA: 45
    Salt: 2550
