Pump percentages
May 21, 2014
63
Frisco, TX
I have a question regarding my SWG. On my Pentair easy touch, I can modify my output by 1% up and down. Does the Intellichlor really modify output at this detailed level, or is it simply in the larger increments located on the machine that light up?
Thanks!
Sent from my SAMSUNG-SM-G891A using Tapatalk
If you have an EasyTouch, the SWG changes in 1% increments, just as requested. The lights on the SWG itself, obviously only show in 20% increments. So, it you set your EasyTouch for 40% you see two lights, if you set the EasyTouch for 55% you get three lights, etc. The lights just give you a general idea of what % is set.
Jim R.
Thank you! I've been adjusting back and forth from 70-60 and there seems to be such a big difference in output it got me wondering. Suppose I'll drop it to 69 and work my way from there.
