Results 1 to 8 of 8
Thread: Adding Borates - A Few Questions
    KatyTXPoolOwner's Avatar
    Jul 2015
    Katy TX
    90
    I'm about to add 55 lbs of boric acid if it will ever stop raining around here. (1st time to address borates; borates are at 0-1, I need 55 lbs boric acid to get to 50 ppm borates)
    With that much to add, are there any suggestions on how to broadcast it across the surface? (half the amount first then test borates, a third of the amount first then measure, brushing in between, etc...)
    Would it make sense to set the filter valve to Recirculate during the process?
    Any other suggestions?
    Thank you!
    23,000 gallon gunite chlorine pool / spa .. French Gray Pebble Sheen .. IntelliFlo VF main pump .. IntelliFlo VS spa booster pump .. WhisperFlo 1HP water feature pump .. LA01N .75HP cleaner booster pump .. Letro Legend Platinum cleaner .. Quad DE 100 filter .. Max-E-Therm 400k heater .. Rainbow 320 chlorinator .. 1.5HP blower .. Easy Touch 8 remote control .. 8 Twirlybyrd jet spa .. Paralevel .. TF-100 w/SpeedStir
    JoyfulNoise's Avatar
    May 2015
    13,193
    Re: Adding Borates - A Few Questions
    Just run your filter pump on high and leave it in filter mode. It dissolves before it will get sucked into the filter.
    Use a plastic scoop or measuring cup of some kind (anything coffee can sized will work) and just scoop & broadcast all around the pool. Once you add about half your bucket, grab your wall brush and start brushing and mixing it up. Once the first batch dissolves, add batch number two and repeat. It's really quite easy to add, requires no pre-dilution in a bucket and dissolves fast.
    Leave your pump running at whatever it's normal speed is for 24hrs then test.
    Matt
    Jul 2015
    Katy TX
    90
    Today marks a new dawn for my pool -- here comes 55lbs of boric acid!
    Starting chemistry:
    FC 6
    CC 0
    pH 7.8
    CH 225
    TA 70
    CYA 50
    BOR 1
    Will update later.
    May 2015
    13,193
    Good luck.
    (I measured my borates yesterday at 48ppm and needed to add 24oz of boric acid to bump it back to 50ppm)
    Matt
    Jul 2015
    Katy TX
    90
    About 3 hours after adding 55lbs boric acid, my pH dropped to 7.5 and borates jumped to 42. Will borates jump up a bit more? If not, should I shoot for getting borates to 50?
    May 2015
    13,193
    Give it more time to mix. I've always waited 24hrs after adding boric acid to measure results. By the way, how are you testing for borates?
    Matt
    Jul 2015
    Katy TX
    90
    I have not yet bought any test for borates - local pool store is testing borates. How do the other TFP'rs test for borates?
    May 2015
    13,193
    Well, perhaps wait another day. Not sure what method the pool store is using but, as you know, you can only trust their testing so much.
    My signature has a link for a drop based titration test for boron using mannitol. I use that procedure for testing and I get fairly accurate results from it. It uses a bunch of reagents from your current test kit but you do need to purchase two more chemicals - mannitol powder and a pH indicator. The details are in the link.
    Matt
