Results 1 to 12 of 12
Thread: CYA Testing
    Aug 2016
    Clay, NY
    19
    CYA Testing
    Hey all,
    I had a quick question regarding testing of CYA. I know the directions for the test state to be in full sunlight with your back to the sun, tube at waist level, etc. etc. However, when following these instructions, the 50 ppm CYA standard that came with my test read approximately 30 ppm instead of 50 ppm. I have read from a couple threads that the correct practice is to just "find a testing place where you get 50 ppm", since the standard is pretty accurate. Is this definitely the right way to treat the standard? I'm asking because I want to make sure I do the test properly, and I will likely have to test it in vastly different conditions than the directions say to get it to read 50 ppm.
    13,500 gallon AG pool, vinyl liner, Sparco SF-40 Sand Filter, Hayward Power-Flo LX pump (1.0 HP, 60 gpm), filled from city water
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Re: CYA Testing
    Do what you can to get the standard to consistently measure 50ppm, then use that method to test the pool water.
    For me, I find that with the Taylor comparator block I have to turn a bit into the sunlight to let more indirect light into the viewtube to get 50ppm with the standard, so I test the pool the same way.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,590
    Re: CYA Testing
    Like Dom said, do, stand, look, be where you need to be to see the standard as 50. Like everything else in life it depends.......some people can see better than others so that will affect the seeing the dot.
    When you are looking for the dot just GLANCE at it. Do not stare or you will see it LOL.
    Jul 2014
    Hope Mills, NC
    567
    Re: CYA Testing
    Using the 50ppm standard, find out what 50 looks like and use that. If YOU still see some black dot, that's OK as long as you are consistent in how you "see" the results that's all that matters.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2016
    MARION, IL
    41
    Cool Re: CYA Testing
    "When you are looking for the dot just GLANCE at it. Do not stare or you will see it LOL."
    Thank you for saying this. I hadn't heard this part of the test before - so it always feels like I'm staring at one of those magic eye pictures, and I just keep seeing that black dot forever it seems. I'm anxious to go test my CYA now with this tip and see what I get.
    D&JButler
    My Pool: 20+K gal vinyl IG; Hayward sand filter with 1 HP pump; Maytronics Dolphin
    May 2015
    Chandler
    107
    Re: CYA Testing
    If you're making it turn out 50 no matter what, how do you know what the actual reading is?
    14,000 gallon pool, plaster, Pentair FNS 60 DE, Variable speed pump, Chandler, AZ (Phoenix area)
    JoyfulNoise's Avatar
    May 2015
    13,247
    CYA Testing
    Quote Originally Posted by myers2115 View Post
    Because the CYA standard solution is an exact composition. The standard is made up in a lab where they precisely measure out the CYA to get a 50 mg/L concentration. Since you know the "answer" before doing the test, then you need to modify the lighting condition so that the test matches the known answer.
    Once you find the test conditions that produces the correct answer, then all subsequent testing on "unknown" samples should be performed in exactly the same manner.
    Matt
    May 2015
    Chandler
    107
    Re: CYA Testing
    Ah. I don't think my test had a standard so I didn't realize such a thing existed. Makes perfect sense, thx. Having trouble measuring my own cya from my pool water.
    May 2015
    13,247
    Re: CYA Testing
    Some of the TF-100 kits from TFTestkits earlier this year were shipped with the Taylor R-7065 50ppm CYA standard reagent. However, because of the round view tube, many testers were reporting that they could not get the standard to show as 50ppm, more like 40ppm at best. So they decided not to include it anymore.
    You're welcome to order some on your own (you can get it on Amazon) to see if it helps optimize your testing routine.
    Matt
    May 2015
    Chandler
    107
    Re: CYA Testing
    Hmmm, can't find on Amazon. Thx anyway.
    May 2015
    13,247
    Re: CYA Testing
    You can order directly from Taylor, it's just more expensive that way.
    Matt
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Re: CYA Testing
    Here is the link to Taylor's reagent:
    Welcome to Taylor Technologies
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
