Thread: Is it okay to replace inlet with fountain?
    essjay75's Avatar
    Jul 2015
    Cypress, Tx
    12
    My above ground pool has only one Inlet and we recently replaced the inlet with a fountain. I just shocked the pool but want to make sure that the shock will circulate okay with just the fountain running.
    (This question is regarding the 16x48 pool)
    As always, thanks SO much for your help/advice/suggestions!!
    14'x42" AG Polygroup Pro-Series, 3300 gal. capacity, SFS1000 filter system, F1000C pump type, Basic vaccum head that came with pool
    AND
    16'x48" AG Intex Round Ultra Frame, 6000 gal. capacity, Krystal Clear Model 635T 1500 gal filter pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Is it okay to replace inlet with fountain?
    If it was liquid yes. If granular then you might want to brush it a little to help it dissolve so it doesn't sit on the bottom.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Back to basics............we don't "shock" pools! We either raise the FC a couple points to help a minor mishap or pre-party or SLAM them!
