Thread: Will emptying the Spa for cleaning cause a pop out?
    Jul 2016
    slidell
    58
    Will draining the spa down 50 % or more for cleaning out dead algae in any way cause a pop out ? Spa is of gunnite construction built attached and along side pool.
    Blue haven kidney style 16,000 gal gunnite including Spa, test Kit TF - 100
    Built 2000 deep end 7.5 feet, 2 steps at shallow end
    Original SWG then convert to chlorine
    Pentair Clean & Clear cartridge filter (4)
    Blue Haven Teledyne Laars Platinum II heater
    Apr 2015
    tucson, arizona
    1,137
    Re: Will emptying the Spa for cleaning cause a pop out?
    Would really depend on groundwater levels. The spa is generally only 3 or4 ft. Deep,unlike the pool which is almost 8. Also you leaving 50% would negate water pressure from below
