Results 1 to 7 of 7
Thread: Calcium Hardness relevant?
    Mar 2016
    Phoenix, AZ
    48
    I have a pebble sheen pool, does calcium hardness matter?
    Current readings: FC 9.0, CC0, PH 7.6, TA 100, CYA 60, CH 400.
    The CH has been creeping upwards, but not too fast. How would a high CH affect a pebblesheen pool?
    10,000 gallon, inground, pebblesheen, sand filter, TF-100 testing kit, Pentair Rebel
    May 2013
    Massachusetts
    148
    Re: Calcium Hardness relevant?
    It matters for scaling AFAIK. If you have a concrete pool with something like Pebbletech then once you get scaling it's hard to get it off and nobody will want to do it for you. It will basically ruin it.
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    You should not add any more calcium to your pool as your AZ water tends to be very hard already, and with evaporation the calcium you have in there will increase. It tends to be an issue (problem) for folks out west.
    BUT...to answer you question fully, yes you need calcium because if your water was light on it it could leech it out from your plaster into the water and weaken your plaster's lifespan.
    Here is a guide to recommended levels-->Pool School - Recommended Levels
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yes, pH, TA and CH are very important to the longevity of your pool finish. Was it new in March? Did you register your warranty on PT's website and receive the 30 day startup and care guide from them?
    Your water is prone to high CH and scale. It is important to maintain your CSI between -0.3 and 0 to prevent scale. PoolMath will give you the number, adjust PH and TA to adjust CSI. More here, Pool School - Calcium Scaling
    Properly managed CSI will add a decade or more to the life of your pool finish. Not managing it could result in failure in as little as 5 years. Which would not be covered by PT's warranty.
    Mar 2016
    Phoenix, AZ
    48
    I try to keep my CSI as close to 0 as possible. The pool tile scaling has been eliminated since I started the TFP method of pool control.
    I was basically just curious if CH was as important for a pebblesheen pool as compared to a plaster pool.
    DFW, TX
    24,483
    Yes, Pebble and quartz pools are plaster pools. It is plaster that pebble and quartz are embedded in.
    Mar 2016
    Phoenix, AZ
    48
    Learn something new everyday, thanks!
