Thread: Slide valve or multiposition?
    Guest
    On all my other DE pool filter they have had the slide valve configuration for the backwashing.
    I see the multi position valve are now another choice.
    Any opinion on one versus the other? The slide looks like simpler installtion since it matches the filter exactly.
    Which is better for the head pressure/restriction?
    Thanks!
    Re: Slide valve or multiposition?
    A multi-position rotary main valve is very nice to have, especially on a DE filter. They do require slightly more maintenance than a plain two position valve, but only just a little. Having the extra settings, like vacuum to waste, recirculate, and rinse is really quite handy.
    Guest
    I wondered what all the other positions would be for.
    Thanks!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Here you can find my feelings on this subject
    Luv& Luk
    -Ted
    Guest
    Thanks Waste!
