Results 1 to 17 of 17
Thread: Not sure where to start
    Jun 2015
    Cross Junction/Va
    54
    Angry Not sure where to start
    my fc 1.5, ph 8, ta 60, ch 160, cya 70.
    And I have yellow algae.
    in ground 24000 gal built 2002 gunite (plaster) Aqualink RS , PDA, spa, cartridge filter, two pumps, Hayward chlorine feeder, blower, heater,
    test kit TF-50.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Not sure where to start
    Hi there
    The answer to clearing your pool of algae is to follow the SLAM process. Pool School - SLAM - Shock Level And Maintain
    Your chlorine is too low for your CYA which is probably why you have algae. Pool School - Chlorine / CYA Chart
    I don't believe the test kit you have includes the FAS-DPD chlorine test that you need to measure higher FC levels required for SLAM. One can be ordered from tftestkits.net.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    +1 to all that ^^^
    Order a TF-100 from TFTestkits.net and when you get it SLAM your pool to kill the algae.
    While you wait brush your pool daily, keep FC around 10 ppm and read this, ABCs of Pool Water Chemistry and this Pool School - Getting Started
    Jun 2015
    Cross Junction/Va
    54
    I did get a TF-50 test kit. Don't know how to edit my info.
    test kit TF-50.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Click on settings and then Edit Signature on the left side of you screen.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    How's the SLAM proceeding?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2015
    Cross Junction/Va
    54
    Got the PH down. Then added 2 gals of 10% bleach to get FC up to 10. And brushed the walls. Will check on the FC in a few hours.
    test kit TF-50.
    Jun 2015
    Cross Junction/Va
    54
    FC is at 15.
    test kit TF-50.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    SLAM for CYA of 70 is 28. More bleach!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2014
    Northern IL
    4,615
    What kind of "chlorine feeder" do you have?
    Jun 2015
    Cross Junction/Va
    54
    Hayward
    I was going by Pool Math. Must have misread. Tks.
    test kit TF-50.
    30,431
    By not adding enough chlorine, you are playing patty cake with the organics in your pool. They will play that game with you forever. It's only when you hit them with a constant sledgehammer (FC 28) that you can successfully clear your pool.
    Reread the SLAM article......you are not doing it yet.
    Aug 2014
    Northern IL
    4,615
    If the chlorine feeder uses pucks, please make sure you remove any pucks that are in there.
    Jun 2015
    Cross Junction/Va
    54
    Will do.
    test kit TF-50.
    Jun 2015
    Cross Junction/Va
    54
    FC at 28. Is it ok to swim with this much chlorine?
    test kit TF-50.
    Aug 2014
    Northern IL
    4,615
    You are right at the cusp of TFP recommendations for swimming. If it were me? I would swim! Just wear old suits just in case.
    TFP recommends being below shock level but above minimum, btw, with a pH of between 7.2-7.8, and water clear enough to see a swimmer in trouble.
    Jun 2015
    Cross Junction/Va
    54
    The FC dropped one over night to 27 and the CC is .5 and the water is very clear. I hope the slam is finished. Thanks for all the help.
    test kit TF-50.
