Results 1 to 8 of 8
Thread: Heater sizing
    Jun 2016
    FL
    901
    Heater sizing
    After following so many recent build projects, I am thinking maybe my heater is too small (Hayward 5hp 140k btu)? We will likely only ever heat the entire pool (34x17 free form; 4-5 feet) for 2 months out of the year but we will use the spa frequently (approx 1-2 times per week). Spa size is 7 foot round. Any thoughts on if I should upgrade before our build?
    Jan 2016
    Mesa, Az
    541
    Re: Heater sizing
    How do you have a horsepower rating on your heater?? I wouldn't use anything smaller than a 400K but heater if you are going to try to heat any size pool.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Heater sizing
    maybe referencing his pump which seems way over sized if it really is 5hp.
    I'm 16x32 3.5 to 7 feet with a 250k btu heater. I'm satisfied with the performance and cost (about $ 30 a month for gas, only using when needed) so that one you have seems a bit small if your asking about it.
    Dolphin E10 Cleaning Robot.
    Jun 2016
    FL
    901
    Re: Heater sizing
    Yes, I misspoke. It is an electric heat pump and not a gas/propane heater. Bjoris, can you elaborate on your thoughts of it actually being oversized?
    Jul 2016
    Niagara Falls, NY
    86
    Re: Heater sizing
    I'm not familiar with Hayward equipment but I have a little bigger pool and pentairs sizing tool led me to a 120k btu heat pump, the btu ratings on heat pumps are less than gas heaters.
    Jul 2016
    Garnerville NY
    76
    Re: Heater sizing
    I'm getting nervous reading some of these responses I have 16x32 free form 20,000 gal. And pb recommended a 117 rheem heat pump
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Heater sizing
    Quote Originally Posted by grumpiebk View Post
    by pump I meant pool pump not a heat pump.
    I don't know anything about those.
    Jun 2016
    FL
    901
    Re: Heater sizing
    As I understand it after doing more research after confusing myself, electric heat pump options only go up to 140K BTU, while gas heaters go up to 400K+ BTU. The heat pump is more cost effective but takes longer to heat. Given I live in south florida and do not have natural gas or propane, the heat pump is a no brainer for me. It may struggle to get my spa to 103-105, but itll do the trick.
