Thread: Spectracide wasp & hornet killer in mah pool
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    So there was some bees on a float, in my pool....lots of bees, i sprayed them with this stuff Shop Spectracide Wasp and Hornet Killer at Lowes.com
    so there is probably a whole can of this in my pool now....should i be worried? lol i'm not a smart person.
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Spectracide wasp & hornet killer in mah pool
    If you're worried.....bump the FC up a couple points and call it a day.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,822
    according to the SDS for the product it contains
    Lambda-Cyhalothrin
    Prallethrin
    patrolium distillates
    isopropyl alcohol
    propane
    and other inert ingredients
    Lambda-Cyhalothrin will break down when exposed to sunlight over a few days. Only highly concentrated exposure has been linked to adverse health affects in humans http://npic.orst.edu/factsheets/l_cyhalogen.pdf
    Prallethrin is persistent and will be in your water for a long time. There is an FDA acceptable limit of 1ppm residual on fruits and vegetable for human consumption.
    https://pubchem.ncbi.nlm.nih.gov/com...mical-Category
    Will 1 cans worth of spray diluted into a pools worth of water kill you no it wont kill you. Is it going to make you sick I dunno maybe. If you can drain and refill without much fuss better to be safer than sorry. Even if its a partial refill that would be better than nothing.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
