Thread: Large Bubbles
    Aug 2016
    Norfolk, VA
    24
    Large Bubbles
    Hi Everyone,
    Have been reading on here all summer and I want to thank everyone for all the help you've given me without having to ask. I am having a new issue though I thought might be better if I ask. We bought a house with a pool last year and had no major issues all summer, however we've started to hit some issues this year.
    I have a 26k gallon Vinyl chlorine based pool with a main drain and 1 skimmer and 2 return ports. About a month ago I started to get small bubbles from the return jets and the situation has been getting worse and worse over the last month. When i turn my 3 way port to the skimmer it works fine with no bubbles at all. As soon as I move that valve away from 100% skimmer I start to get bubbles and will lose prime quickly (5 seconds) if I go 100% main drain. The kicker is that if I turn the pump off, I don't lose prime (or it takes a lot longer if it does) even if I'm 100% main drain.
    What do you think could be the issue? I ordered a new 3 way valve and it's on the way, but do you think that would be the issue? Thanks in advance.
    Attached photo's for reference:
    As a side note, I don't know if it pertains to the above question but my pool keeps losing water to right below the skimmer line, could the leak have something to do with the bubbles? It always gets to the same spot and doesn't go any lower but it happens quickly (fill up to the top and it will be below the skimmer line in less than 24 hours).
    Apr 2013
    Florida
    29
    Re: Large Bubbles
    I'd say first thing is turn the valve 50/50 so you get the air bubbles you mention, then run a garden hose (not full strength) on the suction plumbing and see if the air goes away. Start low and then work upwards.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Large Bubbles
    Welcome to TFP!
    More here on tracking down suction leaks, Pool School - Suction Side Air Leaks
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Large Bubbles
    Are you brushing debris toward the MD in the hopes of cleaning it up?
    Mark
    Aug 2016
    Norfolk, VA
    24
    Re: Large Bubbles
    Thanks everyone. I'm sorry I had to leave for work on short notice and just got home today. I don't typically brush anything toward the main drain aside from any algae that forms. Also, I tried the water trick and had no change in air bubbles. Even wrapped a towel along all of the unions toward the MD and soaked the towel and no change, still losing prime in ~5 seconds. Pooldv, I'll check that forum out and let you know if anything comes up.
    I'm thinking it may be below ground on the MD side, It's just crazy for me to think that its sucking that much air if the union is below ground.
