Results 1 to 7 of 7
Thread: Looking for a product I read about on here.
    Jul 2016
    Chillicothe, IL
    4
    I don't know what it is called. I believe it was used to help eliminate dead spots from water circulation. I believe it was screwed onto the return nozzle in pool. There was a link where to buy it. Sound familiar to anyone? I've been looking for two days.
    Intex 15ft X 48in Easy Set Pool Set
    3,736 gallons. Krystal Clear Cartridge Filter pump, 1,000 gph
    TFTestkits TF-1002 . I fill with well water in Chillicothe, IL.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Re: Looking for a product I read about on here.
    They can be called eyeballs or returns. The actual product will depend on the size of your plumbing, whether it is threaded and what type of threading. Here is an example:
    Amazon.com: Hayward SP1419D White 3/4-Inch Opening Hydrostream Directional Flow Inlet Fitting with 1-1/2-Inch MIP Thread: Patio, Lawn Garden
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,254
    Storm:
    You may want to try both of these returns. How many returns you have in your pool? Please note that if your TA is on the high side, the rotating 360* heads will raise your PH pretty quickly. I had to lower my TA to around 70, which now is at 80 and still holding strong. At even 90-130, I was having rising PH issues.
    Here is a link to both products, which I recommend very highly. It really saves time of not brushing the walls, etc. Always shut off filter if removing or installing any of these jets, especially the circulator as the base can come loose.
    Amazon.com : The Circulator - Automatic 360 Rotating Swimming Pool Cleaner Return Jet with deep heating and chemical infusion : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    The Circulator Rotating Water Jets for Swimming Pools - YouTube
    Infusion V-fitting for Inlet and Return Line, Venturi, White - Home And Garden Products - Amazon.com
    Although, I believe your pool returns may not be compatible. They are standard fittings for your usual in ground pool. If you measure the threads, take a picture, and provide length, I will measure to make sure they bit before you order them.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I added one of the Infusion venturi eyeballs to my deep end return a couple of years ago and can tell it improves circulation noticeably
    Catanzaro's Avatar
    Jul 2014
    2,254
    I added one of the Infusion Venturi eyeballs to my deep end return a couple of years ago and can tell it improves circulation noticeably
    I totally agree. You could feel the pressure difference. I even rotate them upwards when my PH drops (only because of the solar cover) and not 3" pucks. Mind boggling how it creates this power (with only the openings up top). One could actually drill holes through regular return eyeballs to create some sort of effect. I will try this with some of the old ones for next year.
    Jul 2016
    Chillicothe, IL
    4
    Thanks, I think it might have been the Circulator.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to TFP Storm
    Solar Blanket, Well Water, Borax Added. 68
