Results 1 to 14 of 14
Thread: Are these numbers safe to swim in?
    Jul 2011
    Galloway, NJ
    23
    Water is still cloudy but I think we're getting there.
    FC: 14.2
    TC: 14.2
    Combined chlorine: 0
    PH: 7.3
    Hardness: 45
    Alkalinity: 33
    CYA: 44
    18'X48" Summer Waves 7600 gallons
    1 HP Hayward sand filter/pump combo
    TF100 test kit
    Still have so much learning to do
    30,403
    Re: Are these numbers safe to swim in?
    Those test results don't look right. How are you getting them?
    PS - You have too many threads started. It is difficult to follow you around. Please keep your thoughts and questions all under this thread.
    Jul 2011
    Galloway, NJ
    23
    I'm getting them from the hardware store because my TF100 kit won't be here until Monday.
    Sorry for the multiple threads. On other forums, they want a new thread for every question.
    TF100 test kit
    30,403
    I understand. We have too many "continuing stories" where background information is sometimes essential to the current issue. Our discussions work best with the continuity of long threads.
    30,403
    Sorry...didn't answer your question. It's fine to swim in any chlorine less than SLAM value. SLAM value for 40 CYA is 16 ppm.....you are good to go at 14.2
    Jul 2011
    Galloway, NJ
    23
    Thank you. I read that but I still don't trust myself.
    TF100 test kit
    Jul 2011
    Galloway, NJ
    23
    Does anyone know what is causing the cloudiness or how long it will take to go down? I'm not sure if it's just the high chlorine level or something else. There's nothing to vacuum
    TF100 test kit
    Jul 2011
    Galloway, NJ
    23
    Just got my TF100 kit in the mail. Here's the numbers.
    FC 21
    CC 1
    CH 25
    TA 60
    CYA 50
    So according to these numbers, I'm still at shock level and we still can't swim. Starting to get antsy. It's been 5 days since I "shocked" it in the amount that the pool store told me.
    TF100 test kit
    Jun 2010
    Glendale, CA
    513
    Shock level for CYA 50 is 20ppm so you are good to swim.
    Post an update on how your water looks.
    Have you performed an Overnight Chlorine loss test?
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    Quote Originally Posted by Ban26ana View Post
    You can swim up to your SLAM level, as long as you can see the bottom o the pool (for safety sake).
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    High FC doesn't cause cloudiness, it clears it up.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2011
    Galloway, NJ
    23
    So when my FC measured st 21, that wasn't over SLAM level? I'm so confused.
    The water is clear now. I think the cloudiness was because I used powdered "shock" that the pool store recommended, and way more of it than I needed. I've learned my pool store lesson.
    TF100 test kit
    30,403
    By the time you get ready to swim, your FC will be less than 20 ppm. Lightning guy is experienced enough to know that so he tells you you are OK.
    You need to get more familiar with the testing and what the numbers mean. The difference between 20 and 21 is negligible.
    Jul 2011
    Galloway, NJ
    23
    Thank you. I wasn't second guessing him, I was second guessing myself. I thought I was interpreting my numbers incorrectly.
    TF100 test kit
