Thread: adding bleach
    adding bleach
    How long after adding bleach should I wait to get a chlorine reading?
    24ft round 4ft deep sand filter vinyl above ground 13500 gallons
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: adding bleach
    about an hour with the pump running
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: adding bleach
    also you may want to double check you estimated pool gallonage in your sig...a 24ft round usually holds somewhere around 13 to 14k gallons...wouldn;t want you to overdose your pool if using the poolcalculator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: adding bleach
    I agree, you are probably around 13,500, like me.
    Careful with the double postings. I deleted the second one.
