Thread: Sundance Spa Control Panel
    Aug 2010
    Easton, CT
    6
    We had a thunderstorm on Tuesday night which caused the lights to flicker, but we did not lose power. One day later, I went to use the spa and the control panel would not respond. I have attached a picture of the control panel below. I have reset the circuit breaker and nothing happened. I'm wondering if the control board is fried and if anyone has experienced a similar issue. Thanks for your help.
    Figure 8 20'-6" X 35' Inground Pool - Shallow End 3'-6", Deep End 8" - 23,000 gallon pool - Hayward DE 7220 Vertical Grid DE filter - Hayward Mineral Sanitizing System - Hayward
    my-pool-t62997.html
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Sundance Spa Control Panel
    how your power went out is just about the worst thing that can happen to electronics.. it is basically a spike in electricity and loves to fry things...
    You may be able to replace the controller but it may also be the motherboard that is fried..
    Troubleshooting | Sundance® Spas
