Results 1 to 7 of 7
Thread: I have a 2in non union check valve 2lb spring, should i replace with a jandy?
    Oct 2010
    michigan
    284
    Was wondering if i should replace my 2lb spring loaded check valve that is between the heater and chlorinator with a jandy check valve?
    How much better flow would i get? How much resistance is a 2lb spring check valve?
    Thanks
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Apr 2013
    Florida
    29
    Re: I have a 2in non union check valve 2lb spring, should i replace with a jandy?
    If yours is working properly, you wont notice a change in flow. However it should be a non corrosive check valve if its between the chlorinator and the heat pump. One like thishttps://www.yourpoolhq.com/rainbow-r...fSiRoC2GHw_wcB
    Oct 2010
    michigan
    284
    Thats the one i have, does the 2lb resistance effect the flow at all? Only use the chlorinator when i,m raising cya with tabs
    Apr 2013
    Florida
    29
    Nothing that you would notice. And even though you only use it occasionally I would still make sure you keep the non corrosive type on there.
    Oct 2010
    michigan
    284
    Even though my filter/heater is about 1-2 feet higher than the pool water level?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Without knowing details of your plumbing setup it is hard to say the exact flow reduction, but with a 2 pound spring I suspect it is noticeable, and perhaps worthy of the effort and cost to replace. A typical pool spring type check valve will have a 1/4 to 1/2 pound spring.
    Oct 2010
    michigan
    284
    Found a good site for head loss to various pipes/ fittings/ valves
    Swimming Pool Feet of Head Calculations | SPP Inground Pool Kit Blog
    Head loss of 2 isnt much for a check valve.
