Results 1 to 7 of 7
Thread: Newbie needs help
    Aug 2016
    Ocoee
    1
    Newbie needs help
    my husband bought a different brand of shock and dumped 3 bags in the pool before we went on vacation. we've done that in the past, and come home to a perfect pool. but the new shock is not the old shock, and now our CYA is 100 (per pool store). I drained 12 inches and replaced with fresh water. Now the CYA is 110. My FC is 3-4, but I believe that is not enough. I think I have algae forming. It has been a constant problem with this pool. There is no mustard on the walls yet, but the water looks sandy/cloudy. I am skeptical about replacing more water, but don't know what else to do. Someone recommended Bio-Active, but that has very mixed reviews. Any advice appreciated! Thank you!
    Liz, Orlando, FL
    6000 gallon, Inground, Hayward Self Priming Max-Flo Pump, circa 1999 w cartridge filter
    municipal water, screen enclosure
    Jun 2014
    15,012
    Re: Newbie needs help
    Hello and welcome to TFP! Your #1 priority should be testing the water on your own with the proper test kit. I would highly encourage the TF-100 (link below) with speed stir. From there you can confirm the CYA because that will determine how much water will need to be replaced to lower the CYA if required. Until then, I wouldn't do anything to the pool except add about 1/2 gallon of regular bleach to the water each evening. Nothing else. Only with the proper test kit will you solve that mystery, and it's easy to do. Nice to have you with us.
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by Texas Splash View Post
    ^^^^^ What he said
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    30,403
    Welcome to the forum. That "Biobogus" has NO verifiable record of working at all.
    Surf_ox's Avatar
    Aug 2016
    Cypress, TX
    40
    X2 as ^^^^^ said
    I drank that kool aid last year. Might as well flush the $$ down the toilet.
    Don't ever hesitate to try something new. Remember amateurs built the ARK and professionals built the TITANIC.
    13K; IG Pebble sheen [4,5,4] with sun deck; 2hp pentair cleaning the water through a Clean and Clear Plus; 2hp pentair flowing the natural rock waterfall and 3/4 hp powering the 2011 Pentair legend (AKA "THE DUDE")
    May 2012
    Montville NJ
    545
    Just so you know, "shock" - all "Shock" adds CYA. Any chlorine in solid form has CYA in it - pucks, sticks, poweder, whatever. That's just the nature of the beast. Powdered "shock" is nothing different than ground up pucks. For the future, you will do much better by raising your FC using a gallon or two of liquid chlorine (plain old bleach) before going on vacation. It will not add CYA to your pool.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Quote Originally Posted by phonedave View Post
    -dave
    Just to clarify, Calcium Hypochlorite (granular HTH shock from walmart ect) does not have CYA. It will cause your CH to increase.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
