Thread: Going out of town for a few days
    May 2013
    High Point NC
    22
    I'm going to the beach next week and was wondering about my hot tub. I currently use the BBB method on it and wondered if I brought it up to shock level (10ppm) before we left on Tuesday evening would it be ok until we returned on Saturday. It's a 415 Gallon and it will have the cover on it.
    25K Gallon IG vinyl lined L shaped Haywoard Pro Series sand filter, T-CELL-9, Super Pump
    415 Gallon Leisure Bay Spas Elite Series Cordova Hottub
    Jul 2015
    Central Valley CA
    1,109
    Re: Going out of town for a few days
    We will see if someone with spa experience says different but my thinking is if you turn the heat off and assuming the cover is reasonably light tight I don't see any reason the chlorine would not hold at or above suggested levels for a week. The only other factor I can think of is what is the resting temp of the spa without the heat on?
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2013
    High Point NC
    22
    I don't think I can turn the heat off without turning off the breaker that supplies power to the spa. It's only 4 days that we will be gone.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Turning down the heat to 90 or 95 will help quite a bit. Yes, raise to shock level and it should be fine. You can float trichlor puck in there too. Especially if your cya is below 30 or 40.
    May 2013
    High Point NC
    22
    CYA is at 30 as recommended. I'll see about lowering the temp.
