Thread: No flow
    Jul 2016
    San Jose
    11
    No flow
    Hi, my new SWG has worked for a year, but now indicates "no flow" light. Its an aquarite/goldline/hayward.
    I pulled the sensor. It looks magnetic:
    Flow Switch Replacement for Hayward Salt Systems
    I pulled the sensor and plugged the opening. I turned the pump on, then hand closed the flow switch and opened it. No change.
    Next step is to open the front plate and wiggle the plug. The flow is fine, just changed the filter, the flow to the pool is rapid,
    there is only one tube to the pool and it is on it.
    Any suggestions before I drop 32 bucks for a new one?
    Scott Franco
    Meadow's Avatar
    Jun 2016
    Temecula, CA
    237
    Re: No flow
    Don't you want to take advantage of the 3 yr warranty?
    The flow switch is similar to a light switch (ON/OFF). Do you have access to a DVM to probe? Or temporarily bypass the switch using a 2 wire telephone extension cord to test. Cut the other end, twist together the 2 wire, insulate with electrical tape and plug it in. Turn on the pump. If it works then you know the switch is bad. If not, then you need to dig deeper into the Main board or call for warranty.
    Good luck!
    20k gallons, IG plaster with raised Spa, Hayward C-4000 cartridge, Hayward TriStar SP3202VSP, Hayward H400 gas heater, Hayward Super II (2HP) Spa jets, Hayward Swimpure Plus T-15,
    Intermatic PS3000 SPD, PureLine-PureColor LED's, Dolphin Triton cleaning robot, Taylor K-2006, K-1766, OTO Test kit & various Guess strips.
    38,546
    Re: No flow
    Good advice above. Need a little more troubleshooting before you buy parts or call for warranty.
    Jul 2016
    San Jose
    11
    Re: No flow
    Quote Originally Posted by Meadow View Post
    Good luck!
    So sounds like it is a reed switch driven by a magnet. Will try ohming it out, and the bypass thing.
    The 3 year warranty probably has passed. I have a bad habit of buying pool things then letting them sit until I get around to installing them. My bad.
    Thanks for the good info!
    Scott
    Jul 2016
    San Jose
    11
    Re: No flow
    Quote Originally Posted by samiam95124 View Post
    Scott
    Following up, I found the line to the flow sensor was chopped. I'd like to blame it on the rat that has been hanging out in the pool equipment shed, but the cut looks too mechanical for that. It is tie wrapped out of the way, but I have been doing work on the plumbing, so clearly I did it somehow.
    I'm going to take the opportunity to shorten it as well, its like 3 yards of line for the 2 foot run I need.
    Thanks again for the help.
    Scott
    38,546
    Re: No flow
    That is a common problem.
