Thread: Pool leak
    Chisek's Avatar
    Apr 2016
    Homer Glen, IL
    13
    Pool leak
    I have a 20X40 in ground pool with a concrete base & fiberglass walls. The pool has been in the ground since the early to mid 80's. I've been losing about 2" of water a day for the past week. I've plugged the skimmers & not run the pump for a day & I am still losing the same amount of water. I do not notice an "wet" areas around the pool. It does have a concrete patio that is anywhere from 10' to 3' surrounding the pool so I am not sure if I would see any wet areas. What would the steps to start searching for the source of the leak?
    Thanks in advance.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Pool leak
    The most likely culprits are around skimmers, lights and returns. You can let the water leak until it stops and that will point to the area where the leak is. Or you can get some dye or food coloring and check for leaks at these areas.
    Nov 2011
    Moberly,MO
    1,010
    Re: Pool leak
    Look at the wall seams where each panel meets the next. Look at the floor and wall seam also. Do you see any cracks on the concrete floor. Take the light out of the light niche and use red food coloring or phenol red to see if the conduit for the light cord is leaking.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
