Results 1 to 13 of 13
Thread: spa check valve
    Apr 2016
    marana az
    8
    spa check valve
    I'm having a problem with the spa draining down when the pool shuts off. I've read that it's probably the check valve. I've been searching all over the Internet for a replacement. I'll post a pic and hopefull someone has seen this style. Maybe someone has a different solution to my problem. Thank you.
    15k, in ground concrete with spa, aqualink rs, pentair intelliflo
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,477
    Re: spa check valve
    Welcome to TFP...
    Sorry, but none of those look like a check valve to me.
    Send us a pic showing the area at the input to the pump and another at the output from the filter back to the pool. Stand back a couple of feet.
    Apr 2015
    tucson, arizona
    1,117
    Re: spa check valve
    Shop Watts 1/2-in Brass Male In-Line Vacuum Relief Breaker Valve at Lowes.com, this vacuum breaker instead of a check valve. Several pool builders in Tucson use this method.
    Apr 2016
    marana az
    8
    Re: spa check valve
    Thanks for your response.
    I will send more pics of the system today.
    Kadavis, that's exactly what it is. What's the purpose of this valve?
    Mine leaks when it's running. Would that cause air in the system. Any help is greatly appreciated.
    Apr 2013
    Florida
    29
    Re: spa check valve
    I suggest just cutting that out and installing a regualar check valve.
    Jul 2014
    Bedford, TX
    7,477
    Re: spa check valve
    Quote Originally Posted by kadavis View Post
    ka,
    Interesting... Can you tell me the basic way this works in comparison to the standard check valve that only allow water to flow one way?
    Like most people I'm here to learn..
    Apr 2013
    Florida
    29
    Re: spa check valve
    When the pump is on, the pressure pushes the vac breaker closed which seals it. When the pump is off, the vac breaker opens allowing air in, preventing any backwards flow.
    Apr 2015
    tucson, arizona
    1,117
    Re: spa check valve
    Can't see from the picture you posted, but this line actually tee's off from pool return side of three way valve to spa side of valve. There's a valve with red handle that controls how much water will enter spa.The reason they leak is because there is a small gasket inside on a shaft that opens when pump off and closes when on. Over time there's a buildup of calcium and it no longer seals
    Apr 2016
    marana az
    8
    Re: spa check valve
    Thanks for the responses.
    I will take some more pics tomorrow and post.
    I have a few more questions about this type of system.
    Thanks again, Tim
    Apr 2016
    marana az
    8
    Re: spa check valve
    Here are some more pics of the system. Sorry for the side ways pics. I'm new and don't know how to rotate them.
    Here are my questions.
    1. What's the purpose for this vacuum valve?
    2. If that's leaking, could that cause air in the system?
    I just had a new intelliflo pump installed and it seems like there is air in the system.
    3. Should the pump basket be full of water at all times? No air, even at different rpms. At lower speeds the basket doesn't seem to fill all the way up.
    Thanks again for the help, Tim
    Jul 2014
    Bedford, TX
    7,477
    Re: spa check valve
    Tim,
    Most VS pumps have a little air under the basket lid, when running at low RPMs. It is normally nothing to worry about.
    Apr 2015
    tucson, arizona
    1,117
    Re: spa check valve
    I can't see if the ozone unit is on or not, but the blue tubing runs to a small control valve on top of a 3/4" pipe. This pipe goes into the ground and comes backup into a tee on your suction line. If the control valve is slightly open it will let a small amount of ozone gas into system (air bubbles). You can close if not needed. Also Jim is correct at a lower speed the pump will not fill up entirely. Another problem could occur at a lower RPM and the vacuum breaker may not close properly if there isn't enough pressure. The reason the vacuum breaker is there is because your spa is elevated above pool. When your pump shuts off the water in spa wants to seek it's own level with the pool and will drain down until the vacuum is broken. So with this device when the pump turns off it lets air into pipe stopping the siphon. The pool builder has been doing it this way for years.
    Apr 2016
    marana az
    8
    Re: spa check valve
    Just wanted to say thank you to everyone. This site is awesome. I am learning a lot.
    I bought this house in may. I am new to this kind of system. It was salt water. Now its back to chlorine. What Is that blue ozone tube for? Is it part of the salt water system? I think it is off now, but I will double check.
    Thanks again, Tim
